Author Topic: 1977 CB750 K7 Resto-mod, Knoxville  (Read 97597 times)
Offline enwri
  • So that noise is normal?
Re: 1977 CB750 K7 Resto-mod, Knoxville
« Reply #675 on: September 18, 2015, 07:57:19 AM »
What did the plugs you took out look like? when you replaced them on the 16th.
The ones in the previous photos don't look lean, did they look burned clean after riding it around, or sooty.
one of them looked washed clean from unburned fuel.
 aren't they only a few weeks old, they shouldn't need replacing already, or are they the originals from before the rebuild?
Mine will idle but not take any load if my needle is on the second from top , it has to be in the top  (leanest position) with mixture screws at 2 1/4.
Runs cleanly from idle to wide open. A lot of low speed running turns them black but burns off easily with a fast run.
I do have old worn slides and I suspect worn needles as well messing things up.
stock jetting, 4 into 1.
« Last Edit: September 18, 2015, 08:50:21 AM by enwri »
77 CB 750 k.. 29 years and counting.
91 TDM 850 (No.34) so comfy and soft
8? XJ 550 meh...
76 XL 350 Super Sport stump puller..
80 XR 200 idiot proof
75 MX 250 b dangerous
Offline AintNoEasyWay
« Reply #676 on: September 18, 2015, 09:09:57 AM »
Hey enwri, just replaced the plugs this week. Prior to that, I had in old plugs from before the rebuild. I can post pictures of them when I get home. #4 looks too white while the other three seemed somewhat normal. There was some wetness on 1 or more of the other plugs, if I recall correctly. They may be fouled, but I may not be experienced enough at reading plugs to tell.
I think I am going to break down & take it to the shop tomorrow to have them look at it. Missing out on crucial riding time before the cold starts up here in East TN.
« Reply #677 on: September 18, 2015, 10:56:09 AM »
Fall is coming quickly here in NE TN,  the days are staying warm but,  the nights are turning cooler with temps down to 40s some and 50s usually.  That will change quickly in October.
Plug chop at speed will tell you more than just a ride and then pull into neighborhood & to home.
Just need a place to pull it over after shutdown where you can safely work pulling the plugs and swapping in a new set.
This way you can have multiple photos possible and you can capture conditions then and afterwards when cold. Wet plugs will dry is what I am thinking about.
Just about need a case of plugs when playing with jetting and the like. Or a good way to clean them for installing later.
David
« Reply #678 on: September 18, 2015, 01:11:36 PM »
David
David, you're right. The cold is on its way for sure. All good advice, thank you. I am going to take the bike down tomorrow to Rising Sun Cycles in Harriman, TN to have them take a look at it. I'm afraid I'm going to do harm to the newly rebuilt engine if I keep playing with it myself.
« Reply #679 on: September 24, 2015, 05:14:59 AM »
Dropped the bike off at a shop last Saturday & got it back last night. Just needed a good carb sync & tune! Now this thing roars. Took it down the interstate & got it up at 80 a few times. That's the highest I've ever gone on a bike. Guys, I'm in love. These things run beautifully when fixed up properly. So happy I'll get to enjoy at least a few weeks before the cold comes in.
Here's a short video of it running:
It takes a few minutes to get it started & the guys at the shop confirmed these engines run a little cold, but once it gets started it runs great. Thanks for all the help, guys. No way would I have gotten this far without you all. I'll be back during winter to update as I rebuild the front forks, change out steering bearings, & get some new shocks put on.
« Last Edit: September 24, 2015, 05:39:45 AM by AintNoEasyWay »
Offline Restoration Fan
  • My wife will never call me
« Reply #680 on: September 24, 2015, 03:53:00 PM »
She sounds great!  Well done, Nate!
Offline Desert-SOHC
  • It's old
« Reply #681 on: September 24, 2015, 05:20:18 PM »
That's great! It's amazing how much better they run when the carbs are sync'd
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
Offline enwri
« Reply #682 on: September 25, 2015, 01:02:44 AM »
And how it should sound,  good to have a baseline on how it should run.
It might not have been quite right since you've owned it, and unless you have ridden a new one, you would never know otherwise.
P.S.....Always wear a helmet....
8? XJ 550 meh...
« Reply #683 on: September 25, 2015, 08:24:01 AM »
Enwri, absolutely right. I had nothing to compare it to before & didn't realize that it was off. Makes a big difference. I've always got my helmet, gloves, & jacket with me. Thanks!
« Reply #684 on: September 29, 2015, 05:29:10 AM »
When properly tuned, it should start right up as long as you follow the correct procedure.
My bike likes full choke when doing a cold start, if you have PD carbs, give it two twists of the wrist to shoot some gas in the carb.
« Reply #685 on: October 22, 2015, 05:28:58 AM »
Thanks, Stev-o. I assume it doesn't matter that the choke is out when I twist the throttle since the valves have those small holes in them for the accel pump nozzles to shoot through? Just checking.
« Reply #686 on: October 22, 2015, 05:39:05 AM »
What's up guys, haven't updated in a while! I've been busy riding as much as possible before this Tennessee winter hits.
Everything with the bike is good except I seem to be experiencing some loss in power in the past couple weeks. I'm not sure if this has to do with the weather or is carb related. I have to be up in 5th gear by the time I hit 50 mph, which seems like a lower speed than when i first got the carbs tuned up & had it screaming down the interstate.
Also had a mishap with the bike early last week. I parked my bike & went into a coffee shop to get some work done. When I came back out to the bike I had a note on my bike from a girl saying that she had accidentally backed into it & knocked it over. It fell over on its right side & my right mirror scuffed & bent back. Other than that there was no major damage. Fortunately I guess a guy saw it happen & helped her pick it back up. At least she left a note letting me know...
I just ordered some Hagon Type A shocks from Dave Quinn (very helpful guy!), so I'll be adding those to the bike when I rebuild the front forks over winter. Hope you guys are doing well!
« Last Edit: October 22, 2015, 05:46:00 AM by AintNoEasyWay »
Offline enwri
« Reply #687 on: October 23, 2015, 07:55:00 AM »
Does that mean the motor is revving out but you haven't gained speed, or that the engine won't rev fast enough to go faster than 50?
If it's over revving but not accelerating it will be the clutch slipping, either needs adjusting, or it's worn, or friction modifiers in oil.
You can get away with putting spacers under the clutch springs to try to get a bit more "squeeze" into it, for a little while, until you run out of adjustment, but replacing the plates is the way to go.
Mine got knocked over three days after I re-registered it, broke the hi beam filament in the headlight bulb and pushed the handlebars about 2 inches sideways through the clamps, nothing else. It's a tough old thing. But it does wear case savers, I put my feet up on them when I'm going past the nice new Harley dealer on the main street.
Lots of new harleys in Cairns, not too many CBs.
8? XJ 550 meh...
Offline Desert-SOHC
  • It's old
« Reply #688 on: October 23, 2015, 10:42:57 AM »
They do have some weird quirks from time to time. I have noticed that when I'm getting really close to having to go to reserve I cant get Mayble to accelerate past 75mph. If I flip it on reserve there are no issues and I can leave it in "on" as long as I just run around surface streets. It may be time to replace or rebuild the petcock.
11 Ranger S/C 2wd
« Reply #689 on: October 23, 2015, 12:32:47 PM »
Hey Desert, I was searching around the forums for power loss earlier this morning & faulty petcocks definitely seemed to be culprit in some situations.
I can get it up to about 70-75, but that's it. It's as if the bike can't do more than that. Last night on the interstate I tried to get to about 75 & the tach gauge was wobbling back & forth between about 4.5-5k rpms. Could the possibly be a clutch issue?
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #690 on: October 23, 2015, 03:35:29 PM »
Sounds like it's either starving for fuel or low compression. You know these later models have a filter in the tank, above the petcock. Have you checked this filter?
I see in your first post you "de-rusted" the tank. Was there a filter in the tank before you started? Did you remove it? After they have been in there a while they almost start to become "one with the tank" and require some deliberate effort to remove. You can shine a flashlight through the filler opening at the petcock and see if the in-tank filter is in place. Don't use a lighter, or any other type of flame!
« Last Edit: October 23, 2015, 03:44:36 PM by madmtnmotors »
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #691 on: October 23, 2015, 05:02:48 PM »
I replaced the old filter inside the tank when I de-rusted it. Used the pen filter from Honda. Maybe it is compression then. I don't have a compression tester but maybe someone I know does. I'll have to ask around.
« Reply #692 on: October 23, 2015, 06:45:27 PM »
I remember references to an in-line fuel filter in previous posts. So you're using the stock filter in the tank as well as an in-line filter? You can check the flow rate by routing a longer fuel line to a container. I suspected fuel flow issues at one time and measured the flow on two separate K8's side by side. The poorly running bike would only flow half the fuel compared to the properly running bike, but I cannot remember what those volume rates were. I'm thinking one quart in 3-1/2 minutes vs one quart in 7 minutes. I had removed the in-tank filter which in turn had allowed debris from the tank to partially obstruct the petcock. Since you are using the in-tank filter this would not be your issue, but since you are using two filters I'm wondering if the second filter is obstructing flow. This is easy enough to test with a clean container and a watch. Check the flow under three conditions:
>Flow rate through both filters
>Flow rate using just the stock filter in the tank
>If these two values are similar, then loosen the fuel cap and check again with just the stock filter in the tank
This will show you whether the in-line filter is too restrictive, or if your fuel cap vent is obstructed...
and it's free!
TAMTF...
Wilbur
Projects:
Offline Desert-SOHC
  • It's old
« Reply #693 on: October 23, 2015, 07:54:16 PM »
I remember in the gas crunch in 79, with every station pumping there tanks dry. I had to remove my petcock 3 or 4 times to clean the filter and all the crap out of the petcock itself. Might be time for me to check mine out, I never really removed the petcock....just made sure the tank was clean.
11 Ranger S/C 2wd
Offline enwri
« Reply #694 on: October 24, 2015, 02:17:05 AM »
No, doesn't sound like it.
8? XJ 550 meh...
« Reply #695 on: October 24, 2015, 06:47:26 AM »
I concur. A slipping clutch would let the engine rev much higher without producing any more forward speed. I can only come up with three potential culprits:
>Fuel restriction
>Something in the ignition system failing under load (points, condensers, coils, plugs)
>Low compression. This can be worn rings, worn valves, or valves adjusted too tight (not closing)
I recommend a compression test before buying any parts.
TAMTF...
Wilbur
Projects:
« Reply #696 on: October 25, 2015, 04:14:01 AM »
Do you get to WOT at 75, or is therea sudden lose of power at that level?
I had the later and it was during tuning jets/clip position, when the pilot jet no longer supplies enough fuel.
« Reply #697 on: October 25, 2015, 12:27:21 PM »
Could you pull the spark plug caps and check their ohm reading out of the circuit?  They could cause some issues at higher revs.
The fuel bowls running out of sufficient flow could do it as well.  A cheap Chinese petcock could just not pass enough fuel due to bad design/quality control.
Time the tank to fill a quart container from the petcock after checking the caps.
Double check the points and advancer is fully advancing.  Also that you are not getting some arcing at high rpms on paths that could sort the power to thr coils at around the points.
Condensor might be weak. What brand and how new?
David
« Reply #698 on: October 25, 2015, 01:03:35 PM »
IIRC, he's running a Pamco electronic ignition.
Offline Desert-SOHC
  • It's old
« Reply #699 on: October 25, 2015, 02:41:49 PM »
When below 2/3 of a tank my petcock doesn't flow enough to let me rev over 4500rpm
11 Ranger S/C 2wd
