Was that bike being run by PO without front brake?
Front wheel is back to front.
It was popular for a while to flip the front brake to the opposite side. When you have long forks, the over-center mass of the larger K0-K2 calipers adds "swing weight" to the steering. This is not a bad thing at speed, as it helps hold the straight line, but in parking lots it increases the work of turns, and with extended forks that's already a big deal.
The flip side: water collects against the pucks in the wet. This causes quite a delay when applying the brake in the wet. It also increases corrosion and dirt collection in the cavities around the pucks. The "other" bikes out there with the calipers behind the forks have either big troubles with this, or a different caliper design to try to cope with it. Today, in the interests of cheaper manufacture, most bikes just have the calipers mounted directly to the fork leg, behind the fork(s), but have a more intense maintenance schedule to keep them operational. (In "real" life, though, this usually fails, in my experience.
