Author Topic: Rims from other bikes  (Read 920 times)
Offline jimford75
« on: April 25, 2014, 08:47:03 PM »
I am new here.  I have a 73 cb750k and I was wondering what newer front forks fit and what rims from different bikes would bolt up.  I would like inverted crotch rocket forks uo front and a little but wider tire on the back.  But I want spoked rims.  I really have no clue as to how to figure this out.  Thank you guys.
Re: Rims from other bikes
« Reply #1 on: April 25, 2014, 09:49:29 PM »
Jim,
The easiest front end conversion would be a Suzuki GSXR front. Take a look at Cognitomoto.com. Devin has hubs that will allow you to run spoked wheels with the modern forks and brakes. He has all of the parts you will need to swap in a 750 length steering stem into a GSXR triple or he will even do it for you. He will even sell you a turn key kit to swap onto your 750.
Don
Offline calj737
  • I refuse...
« Reply #2 on: April 26, 2014, 05:16:05 AM »
And depending upon year,your rear rim can be increased in width too, but you have to take into account diameter plus width when calculating interference between the tire and the swing arm. Measure carefully on the right edge of tire towards the swing arm. Generally speaking, a 130 tire fits, but 140 and greater can be problematic on both sides, requiring offset sprockets, etc.
+2 on CognitoMoto hub/front end.
