Author Topic: Help! Bike's done and discovered oil leak at valve cover gasket.  (Read 3432 times)
Offline Jayelwin
So I'm done with my CB750 K5 build and I let it warm up to sync the carbs and noticed oil on the floor. Traced it back to a leak right at the valve cover, right smack dab in the middle at the front just above the well for plug 2 and 3. The screw at that point only holds the top breather cover on - the screws for the valve cover are under the breather cover.
I REALLY REALLY don't want to pull the engine on this now that I'm done. I was wondering if possibly removing all the valve cover screws (some will be hard to get to) and then lifting the valve cover as much as possible and making sure the gasket is lined up properly (I know you can't remove it). Then torquing down the screws again.
Some of these screws are going to be hard to get to - gonna need to get some sort of angled bit to get around the frame rails.
Any advice? Thanks.
Offline Jayelwin
Re: Help! Bike's done and discovered oil leak at valve cover gasket.
« Reply #1 on: April 27, 2014, 03:43:26 PM »
Oh, and it's on a new gasket I got from 4into1
Offline Old Scrambler
« Reply #2 on: April 27, 2014, 05:59:52 PM »
Just as you expected............take it easy...........they should be snug............if all is installed properly, just snug tight when cold..............then re-do after a warm-up.....................I have a few small blocks of wood to hold the cover up while the gasket is aligned.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
DH
« Reply #3 on: April 27, 2014, 07:31:48 PM »
it's been said that Honda mechanics back in the day could flat rate a valve cover gasket without pulling the engine. After removing the valve cover screws and raising the cover as far as possible, cleaning the surface, and maneuvering a new gasket OVER top of the cover, starting at one side, and progressively tucking the gasket underneath while moving to the opposite side. Once you've maneuvered it over the cover, line things up and put the cover bolts back in. I have never done one, but have done 1 piece oil pan gaskets on cars and trucks using the same method with good results.
Offline Jayelwin
« Reply #4 on: April 27, 2014, 07:40:01 PM »
Do you think I should first try to remove the breather cover and re torque the bolts at the leak point?
« Reply #5 on: April 27, 2014, 08:12:28 PM »
I have replaced valve cover gasket with the engine in the frame before.  Here are some tips to help-
1.  You gotta remove the tank of course, and the coils and their brackets.
2.  Get yourself a right angle screwdriver.
3.  If you unhook everything that doesn't flex (like exhaust, airbox, all the engine mounts and bolts) you can sort of rotate  the engine up in back and down in front to gain a little extra room.  This may not be an option if nice new paint is involved.
Offline Jayelwin
« Reply #6 on: April 27, 2014, 08:45:19 PM »
The gasket is a brand-new gasket, I'm hoping it might just not be laying right and might need to be shifted and then the cover retorqued
Sent from my iPad using Tapatalk HD
« Reply #7 on: April 27, 2014, 09:05:56 PM »
And remember it is not symetrical. It only goes one way. Be sure you've got it right side up before manipuaitng under the cover.
If you decide to replae it.
Offline Jayelwin
« Reply #8 on: April 28, 2014, 05:27:10 AM »
It's a fairly brisk leak.
I bought a screw kit and those screws were too long. I trimmed them down but I'm secretly hoping that they're still too long and bottoming out in the head.
Offline Jayelwin
« Reply #9 on: April 28, 2014, 05:27:38 AM »
I would definitely consider a frame kit - any info or web page to look at?
« Reply #10 on: April 28, 2014, 07:34:26 AM »
The gasket fits over a few dowels, most of it can't move.
 If its just in one spot you can see, try this. Unfortunately valvecover, lift nd hold up with wire or whatever.thengently lift gasket in that leak are
Offline Henning
« Reply #11 on: April 28, 2014, 10:19:51 AM »
Picture of how I did mine...
To refresh, tank off, coils off, support the valve cover properly so you're not fighting that as well, remember to orient the gasket correctly, and get the genuine Honda gasket. It's quality, and it can handle being massaged over the valve cover (twice, I put it in the wrong way round first).
The bolts for the breather cover are quite long and you might have problems getting them off. I did, but I wasn't too concerned about a bit more patina on the frame. If it is a problem you can follow the advice about removing the engine bolts to get more clearance.
71 or thereabouts 750 K1 - this one should have been put down
Offline Jayelwin
« Reply #12 on: April 28, 2014, 06:24:15 PM »
Well I was able to get the breather cover off and the two screws under there were able to be turned more than a quarter turn each pretty easily. Let's hope that stops the leak or I've got more work to do.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #13 on: April 29, 2014, 05:57:18 AM »
I think I have a leak right in the same place. I'm putting new oil in this week, and I will be keeping a very close eye on the leak this season. May have to do the same thing as Jayelwin!
--Evan
1975 CB750K "Rhonda"
