Author Topic: CB500/550 swap clutch  (Read 735 times)
Offline michael_brown
  • it is what it is
« on: April 28, 2014, 05:18:15 PM »
I swapped a 550 motor from a 1974 bike into my 73 CB500. I purchased motor mounts from eBay so that it would have the correct bracket for the clutch cable. I installed the motor this weekend but do not have enough clearance for the clutch cable to mount or work properly. Anyone have any ideas/suggestions?
Re: CB500/550 swap clutch
« Reply #1 on: April 28, 2014, 06:49:22 PM »
Dave will know...where are you Dave???
Offline wowbagger
  • Not much of an
« Reply #2 on: April 28, 2014, 07:25:44 PM »
Is it just the photos or is your clutch arm actually that flat? It's supposed to have more of a bend to it. Like this:
« Reply #3 on: April 28, 2014, 07:35:29 PM »
should be a curved bent arm,youll need the 550 cable aswell the 500 one wont work.
« Reply #4 on: April 29, 2014, 01:00:24 AM »
if your running out of travel make sure that the cam inside the housing is the correct way on its shaft,its not the snail curved part that contacts the release rod internal lever but the flat section actually does the pushing!if the lever is too high that might be your problem along with the already tampered with external arm?
  • it is what it is
« Reply #5 on: April 29, 2014, 03:05:34 AM »
Yeah. External arm is that flat. Looks like I'm searching for one of those.
