Author Topic: carb probs  (Read 1802 times)
Offline cb(r)
carb probs
« on: September 16, 2006, 07:16:57 AM »
71 cb 350.
running condition:  I can kickstart the bike and it idles about nice but slightly on the rough side.  this condition was before and after I rebuilt the carbs.
the problem:  when I twist the throttle (slow or fast) the bike bogs down and then dies.  a couple of kickstarts and it starts and idles again.  I do, at the moment have the air cleaners off.  I had them on and off prior to carb rebuild.
I set the idle mix screws at diff position and it did nothing.
could there be an air leak on the intakes?
head gasket?
I also put new floats in maybe they need adjusting?
help I am almost out of ideas.  the big hammer technique is starting to be my only option.
thanks in advance.
kevin
Offline KB02
Re: carb probs
« Reply #1 on: September 16, 2006, 10:30:11 AM »
two ideas off the top of my head:
1.) Check the Neddles. Make sure they are raising when you twist the throttle. They might be broken.
2.) How is your timing?
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
-Pod-
Re: carb probs
« Reply #2 on: September 18, 2006, 02:04:32 AM »
Turn the choke off?
Offline cb(r)
Re: carb probs
« Reply #3 on: September 18, 2006, 05:19:24 AM »
ya needles are fine they are working well.
I will check the timing though.  I just wanted to make sure there was not something I was overlooking on the carb side.
thanks for the input
Offline cb(r)
Re: carb probs
« Reply #4 on: September 18, 2006, 05:22:58 AM »
Turn the choke off?
 I tried with choke off and on.  still I have probs I think KBO2 is probably right.  I really was hoping it would be something easy like the choke though.  thanks for the post
