Author Topic: 1977 CB750F1 UK Spec Seat cowl pinstriping and side cover colour  (Read 1404 times)
Offline martin_uk
  • CB750F1 CB750K8
Hi, hope somone with more knowledge on original spec can help.
The rear seat cowl (end cover) on a Sulfur yellow (y34) bike has a blue pinstripe, was this original?
I have found some images with on line but not in US brochure.
Info on here suggest side panels should be black, but ones that came with bike are a dark, slightly metallic grey.
Seat side strips have a thick yellow stripe applied, initially thought non standard but see parts list shows these in different colours?
Any guidance would be appreciated.
CB750F1, CB750K8,  Triumph Street Triple R, AJS 350, Triumph 3TA
Offline martin_uk
  • CB750F1 CB750K8
Re: 1977 CB750F1 UK Spec Seat cowl pinstriping and side cover colour
« Reply #1 on: May 01, 2014, 10:34:49 AM »
Image of cowl and tank
2014_0430cb750B40032 by nitram2010, on Flickr
2014_0430cb750B40021 by nitram2010, on Flickr
« Last Edit: May 01, 2014, 10:58:22 AM by martin_uk »
Offline andrewk
  • doin' it.
« Reply #2 on: May 01, 2014, 07:33:39 PM »
Stripe is factory as far as I can tell, you are correct that side covers should be a dark metallic grey. Seat trim was colored to match the paint, they used a vinyl inset on the stainless seat trim.
Offline david 750f
  • 1976 CB750F
« Reply #3 on: May 01, 2014, 09:09:03 PM »
No factory stripe on the tail piece but the tank looks correct.
Even though the side covers are "phantom black", the paint is more flat grey/black.. No clearcoat on the side covers.
Pics of my never used NOS sidecovers..
1976 CB 750F
Offline martin_uk
  • CB750F1 CB750K8
« Reply #4 on: May 02, 2014, 05:24:27 AM »
Brilliant, thanks
Offline martin_uk
  • CB750F1 CB750K8
« Reply #5 on: May 02, 2014, 05:26:10 AM »
Many thanks
Offline Vin750
« Reply #6 on: January 28, 2018, 11:31:19 PM »
Do you happen to know if the F2 had clear coat on the side covers and rear cowl?
