Author Topic: Need Kits for These Carbs. What Model?  (Read 626 times)
Offline krusty
« on: May 01, 2014, 10:40:54 PM »
My mate has this set of carbs but does not know what model bike they are off. He suspects CB650. Would like to know for sure so that he can order kits for them. Plans on fitting them to his S600.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Offline mrbreeze
  • Not your average
Re: Need Kits for These Carbs. What Model?
« Reply #1 on: May 01, 2014, 11:26:40 PM »
You might find a fitment chart on the internet and I'm sure the dealership would have it. Maybe check with one of our carb builders here. You could probably make any set of carbs work but if you want plug & play find the match from the chart.
MEMBER # 257
Offline bytio
« Reply #2 on: May 02, 2014, 12:02:58 AM »
PD 42B used on CB 750 F2SOHC 1978
Offline brewsky
« Reply #3 on: May 02, 2014, 04:58:41 AM »
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #4 on: May 02, 2014, 11:34:30 AM »
Yep, 1977 CB750 F2. They have needles with adjustable clip positions FYI.
Build threads:
1977 CB750 F2
1958 Norton Model 99
« Reply #5 on: May 02, 2014, 12:57:54 PM »
+3  77 750F carbs...but it looks like they were stripped of a few items along the way.
fuel lines, accel pump fuel circuit lines, fast idle cam, choke linkage......
might take more than a few 'kits' to get these sorted  :-\
Offline harisuluv
« Reply #6 on: May 02, 2014, 01:49:40 PM »
Yup missing a lot on those.  I have all the parts, replated for the most part.  I would recommend you do a more detailed inventory of what you're missing though, otherwise you'll be buying piece by piece and constantly realizing you need something else.
Offline krusty
« Reply #7 on: May 02, 2014, 03:34:25 PM »
Thanks heaps guys. I perhaps should have recognised them as I have a 78 750F but its been a while since I looked at the carbs. As I said in OP my mate wants to set these up on his S600 so there will be some mods required.
Thanks for the offer harisuluv, I'll keep it in mind if he needs anything.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
