Author Topic: Front brake caliper pin question  (Read 1138 times)
kaysystems
« on: September 16, 2006, 01:56:52 PM »
My pads wears uneavenly.
The pin holding the front brake caliper arm is a loose fit in the bracket, but fairly tight on the arm. This means that it rattles in the bracket.
Shouldn't it be a tight fit in the bracket & the arm rotate on the pin?
David
Re: Front brake caliper pin question
« Reply #1 on: September 17, 2006, 01:28:19 AM »
Should be tight in he bracket and loose in the arm, sounds like yours siezed in the arm and wore the housing.You realy need to replace the bracket
kaysystems
« Reply #2 on: September 17, 2006, 05:24:19 AM »
Thanks
That's a little job to do over the winter..
David
