Author Topic: Where do I place a battery?????  (Read 834 times)
Offline Dion
« on: May 04, 2014, 10:26:52 am »
Hi Chaps, I’m trying my best to replicate the Honda CR.  BUT I need a starter motor. So I’m deviating from the original. Now the million dollar question. Where do I place a battery????? What batt do u guys use for a total loss electrical system????
Offline Tintop
Re: Where do I place a battery?????
« Reply #1 on: May 04, 2014, 11:12:37 am »
If your only powering ignition, and 1/2+ hour will do; then a Lith/ion should fit under the swingarm, and behind the case.  Probably last longer, than that, but need to hear from someone using that setup (bwaller??).
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
« Reply #2 on: May 04, 2014, 11:32:43 am »
I use 8 cell lith/ion batteries on total loss. They probably would last 45 minutes depending on ignition draw.
Offline Dion
« Reply #3 on: May 05, 2014, 01:42:52 am »
Hi, Thanks Chaps. Do you have an example of this batt? Can i start up with it as well? where do u place it?  Thanks for all the help
Offline johno
« Reply #4 on: May 05, 2014, 03:07:27 am »
Mate, these lithium batteries are awesome , amazingly light, install any position sideways , upside down , got to be carefull with your battery charger type,   dont lose much charge with time eg 12 months   for a total loss system I dont know  if there is a better battery,
Oh I didnt end up running it in the starter hole , the suggestion under the swing arm sideways sounds like a good idea, I just posted a pic to give you a feel for an 8 cell.
cheers johno
GRASSHOPPER SOHC HONDAS ARE THE MEANING OF LIFE.
Offline turboguzzi
« Reply #5 on: May 05, 2014, 04:04:54 am »
if you are going with lion, your bike better be fine tuned for easy starting, they tend to loose quite  a bit of power after three-four tries.
with current EFI bikes this is not a problem, but with a old carbie one it could be.
im all for gel ones these days. sure not as light as lion, but amazing cranking power.
