Author Topic: Which way does the oil filter housing go on?  (Read 1683 times)
Offline Loudpipe
  • Broken Vehicle Collector
« on: September 16, 2006, 07:55:47 PM »
I'm confused as to which side is up on the filter housing itself, and then the housing piece which goes between the piece which holds the oil filter and the actual engine. Can anyone enlighten me with a detailed description or a nice picture?
This'll teach me to pay more attention when I'm taking things off for the first time!  Also, since both of these "housings" have large o-rings, and the filter kit only came with one, would it have been better to replace the one which goes against the engine, or the one in the primary housing which fits against the smaller housing? Neither were leaking at all before.
« Last Edit: September 16, 2006, 08:02:37 PM by Loudpipe »
- LP
1974 Honda CB350F
Previous: 1978 Honda CB750F, 1971 Honda CB500K, 2009 Yamaha YZF-R1
Ratfink
Re: Which way does the oil filter housing go on?
« Reply #1 on: September 16, 2006, 08:05:50 PM »
The longer fins go up. I would replace the filter between the housing and the engine.
http://hondachopper.com/images/oil.filter.pan.diagram.gif
Click on the picture and you will get a enlarged view.
« Last Edit: September 16, 2006, 08:07:27 PM by Ratfink »
Offline Loudpipe
« Reply #2 on: September 16, 2006, 08:15:05 PM »
OK. Mine has an extra piece that isn't shown in any of the pictures I've seen so far though. It's a completely seperate piece which goes between that filter housing and the engine, has fins, and has a sort of bushing to keep it centered on the oil bolt. Was that a special 'F' engine thing or something?
- LP
1974 Honda CB350F
Offline Einyodeler
  • Midnight bugs taste best!!!
« Reply #3 on: September 16, 2006, 08:20:01 PM »
Sounds like an oil cooler adapter. Got a pic?
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
Offline scondon
  • Mmmm......tasty bugs
« Reply #4 on: September 16, 2006, 08:22:27 PM »
Ahhh, the two piece 77-78 750F sandwich :D    The longer fins of the cooling plate point down. If memory serves there is a locator tab at the top of the filter housing which fits between two tabs on the cooling fin back plate. I replaced the O-ring between the filter housing and cooling plate the first time and made sure to have two O-rings at the next oil change. I have re-used these large O-rings before and didn't have any problems with leaking. Just make sure everything is clean and that no engine grit has made it's way on to the mating surfaces.
« Last Edit: September 16, 2006, 08:52:29 PM by scondon »
Offline scondon
« Reply #5 on: September 16, 2006, 08:29:01 PM »
Oops, my bad, I just peeked in the garage and the long fins point down. There are two locating tabs on the engine that the cooling plate slots into and two tabs on the cooling plate that the filter housing slots into. Changing my above post to read "large fins down".
Offline Loudpipe
« Reply #6 on: September 16, 2006, 08:44:08 PM »
#$%*. I've got the long fins of the cooling plate pointing the correct direction (because they have too in order to fit), down, but the long fins of the oil filter housing pointing up. Is this alright until the next oil change? I really would rather not drain all the new oil out of the oil filter housing again.
- LP
1974 Honda CB350F
Offline scondon
« Reply #7 on: September 16, 2006, 08:47:58 PM »
I'm sure it's allright and may even be correct. Mine has been disassembled for a long time and I was just looking at the pieces. The long fins on the cooler plate need to point down and that is what got me to change my post. Theres nothing in the filter housing that will be affected by mounting in either direction.
Offline Loudpipe
« Reply #8 on: September 16, 2006, 08:50:09 PM »
Ok, good. Thanks for the info scondon, much appreciated.
- LP
1974 Honda CB350F
