Author Topic: velocity stack  (Read 892 times)
Offline el__burro
velocity stack
« on: May 05, 2014, 03:12:23 pm »
Hello,
I am planning to replace the air filter with 4 velocity stack.
What is the diameter I need to look for.
Bike is a cb750 k2.
Thanks
el__burro
Offline Stilltime
  • Building my Dream
Re: velocity stack
« Reply #1 on: May 05, 2014, 03:26:57 pm »
Check out Steel Dragon Performance, they'll get you hooked up!
'78 CB550 - Orange Crush
Offline Stoli
Re: velocity stack
« Reply #2 on: May 05, 2014, 07:12:22 pm »
I'd measure the intakes to be sure. Never know if a PO replaced the carbs at some point. They are most likely either 40mm or 44mm.
My Project Threads:
Project #1 - http://forums.sohc4.net/index.php?topic=117106.0  First bike
Project #2 - http://forums.sohc4.net/index.php?topic=127364.0  Something different
Project #3 - http://forums.sohc4.net/index.php?topic=123831.0  Long and Low
Offline dusterdude
Re: velocity stack
« Reply #3 on: May 06, 2014, 09:48:59 am »
Iirc,they are inch and a half od
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline andrewk
  • doin' it.
Re: velocity stack
« Reply #4 on: May 06, 2014, 10:19:59 am »
round tops are 40mm od, just proud of 1.5 inches.
Offline jdubb1977
Re: velocity stack
« Reply #5 on: May 07, 2014, 09:04:10 am »
+1 for Steel Dragon.  I sent them a picture of my carbs just to make sure, and they replied right away confirming that their stacks would fit.
