Author Topic: CB550 Starting Woes  (Read 2207 times)
Offline gregripko
CB550 Starting Woes
« on: May 05, 2014, 03:20:19 PM »
The bike started amazing for about year but recently I've been getting hit and miss with the starter.... It clicks and and I notice lights dim but does not turn over except on rare occasions (most of the time I kick start because it turns over first kick). Reading online I was able to put key in the ignition to start and using a screwdriver I bridged the solenoid points which caused the bike to fire right up no problem immediately. From this info can you guys help me out? I'm not an electrician by any means. Ty
Offline rb550four
Re: CB550 Starting Woes
« Reply #1 on: May 05, 2014, 03:35:21 PM »
Could be corroded starter button, clean up the contacts a bit and see if that improves the issue.
You could put a tester light on the starter wire to be sure that current is flowing to the other post when you push the button
If it still doesn't turn over and you have current going to the starter , you may need to try a different starter (don't know what parts collection you have) to double check that the starter itself  is surely the issue...... removed starter can be spun by hand, you can feel if there is a very tight spot in it, or locked up, that would indicate  a problem with the first starter.
« Last Edit: May 05, 2014, 03:37:38 PM by rb550four »
Offline gregripko
« Reply #2 on: May 05, 2014, 03:47:02 PM »
Ok... Any recommendations for a cleaning contacts?
Offline rb550four
« Reply #3 on: May 05, 2014, 06:02:36 PM »
Might as well pick up a test light while you're there too.
« Reply #4 on: May 05, 2014, 06:14:25 PM »
Rb550 nailed it, it's your starter button.  I have not had good luck repairing them, I usually just replace, not too expensive.
If cleaning fails......
http://www.ebay.com/itm/Vintage-Honda-CB750-CB550-CB500-Right-Control-Start-Switch-Run-Off-Kill-575-/141271135299?pt=Motorcycles_Parts_Accessories&hash=item20e46a7443&vxp=mtr
Offline gregripko
« Reply #5 on: May 05, 2014, 06:41:32 PM »
You guys Rock Ty..... I'll give it a go and see how things turn out.... Luckily I can give it a swift kick and it starts up no issues until I resolve it
« Reply #6 on: May 05, 2014, 06:45:16 PM »
The US Cb550 line :
1974 CB550 K
1975 CB550 K
1975 CB550 F
1976 CB550 K
1976 CB550 F
1977 CB550 K
1977 CB550 F
1978 Cb550 K
Fs and later Ks used a different start button than the early Ks.
You'll need pretty good prowess to clean the F and late K starter switches.
Offline gregripko
« Reply #7 on: May 05, 2014, 06:48:41 PM »
76 550k
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #8 on: May 05, 2014, 08:34:53 PM »
Yep I had to replace mine on both my 550s. Found a good used one on EBAY haven't had a miss start since on the K. I had to buy a new one for my F model, it was around $100.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline gregripko
« Reply #9 on: May 05, 2014, 08:44:35 PM »
Hmmm..... Do I have to get my exact year and model letter?
76 cb550k
Offline Rgconner
« Reply #10 on: May 06, 2014, 06:40:59 AM »
Use the kickstarter.
 :o
1975 CB550K aka "Grease Monkey"
Offline Airborne 82nd
« Reply #11 on: May 06, 2014, 07:36:37 AM »
Quote from OP " Reading online I was able to put key in the ignition to start and using a screwdriver I bridged the solenoid points which caused the bike to fire right up no problem immediately."
Wouldn't this mean the starter is OK?
Offline gregripko
« Reply #12 on: May 06, 2014, 09:48:57 AM »
I've seen aftermarket starter switch/buttons on these bikes but I'm guessing they're a lot more expensive than just picking up a used one....
Offline gregripko
« Reply #13 on: May 08, 2014, 11:59:15 AM »
Cb550 Starter Button After Contact Cleaner
I sprayed contact cleaner in the starter button switch area to clean out the crud that had accumulated and it seems to be doing ok now.
« Reply #14 on: May 08, 2014, 03:46:26 PM »
Yes
Offline Vinhead1957
« Reply #15 on: May 08, 2014, 04:43:51 PM »
What it also means is the starter solenoid many be bad or the starter button circuit.
Offline Vinhead1957
CB550 Starting Woes
« Reply #16 on: May 08, 2014, 04:49:35 PM »
I also have had a bad connection in the headlight bucket the red/green wire feeds the 12v to the button circuit
« Last Edit: May 08, 2014, 04:53:20 PM by Vinhead1957 »
Offline gregripko
« Reply #17 on: May 08, 2014, 05:51:25 PM »
Did you see the video I posted? It's starting fine now....in fact this morning I fired it up and it started up faster than it ever has
Offline RodPlunger
  • Annoying New Guy...
  • The road goes on forever....
« Reply #18 on: May 08, 2014, 11:29:03 PM »
What's up with the delay in your rpm being shown? In the video?
1977 CB550F Supersport
"We want to be free.
We want to be free to do what we want to do.
We want to be free to ride.
We want to be free to ride our machines without being hassled by The Man...
And we want to get loaded!
Offline gregripko
« Reply #19 on: May 08, 2014, 11:39:01 PM »
Eh I've never really noticed because after startup it functions perfect.... Has a tiny delay but maybe it has to register? Kinda like when you check your pulse.... You can get a more accurate reading with time elapsing. I may be wrong but that sounds like a good explanation. I started bike up tonight to ride home and it fired up like a champ. Whatever it was is now resolved after using electric contact cleaner
« Reply #20 on: May 09, 2014, 04:55:49 AM »
That does look odd.  May want to lube your cable.
Offline gregripko
« Reply #21 on: July 18, 2014, 08:01:19 PM »
Ok so this is where I'm at:
Cb550 only starts if I pull clutch or kick
Bike also starts when I bridge solenoid with screwdriver
Any ideas?
« Reply #22 on: July 19, 2014, 09:25:12 AM »
Any ideas?
Bad starter switch on right control is my guess.  Very common issue, I just ordered a new control from Partzilla for my 550F.
http://www.partzilla.com/parts/detail/honda/HP-35130-377-P00.html
Offline gregripko
« Reply #23 on: July 19, 2014, 09:54:44 AM »
Why does the starter button work with clutch pull?
Offline gregripko
« Reply #24 on: July 19, 2014, 03:19:06 PM »
Is the clutch grounding what the starter switch normally grounds? Just trying to understand what's going on from an electrical standpoint
