Author Topic: 1971 CB350 clutch  (Read 5028 times)
Offline tenseventythree
1971 CB350 clutch
« on: May 07, 2014, 07:11:40 PM »
I have a bent clutch push rod. I ordered a replacement but I need to know how to remove the old one.
I can't find the procedure anywhere.
Need help.
1969 Suzuki M15-2
1971 Honda CB350
1974 Honda CL360
2012 Triumph Bonneville T100
Using Tapatalk
Offline calj737
  • I refuse...
Re: 1971 CB350 clutch
« Reply #2 on: May 07, 2014, 10:50:00 PM »
CB350 Twin, or Four?
« Reply #3 on: May 08, 2014, 10:00:42 PM »
Twin
1969 Suzuki M15-2
1971 Honda CB350
1974 Honda CL360
Using Tapatalk
« Reply #4 on: May 11, 2014, 12:16:25 PM »
You just pull off the case where the lifter is, and pull it out. If the other end can't be fished out with a magnet, then you'll have to also pull off the clutch cover case and pull off the clutch pressure plate, under which you'll find the lifter. This just pulls out, then you'll find the other pieces of the rod in the tunnel that goes through the mainshaft to the other side.
« Reply #5 on: May 13, 2014, 06:52:22 AM »
Did it and done. Waiting on a seal to come in from the bay area. Didn't anticipate that much oil though.
1969 Suzuki M15-2
1971 Honda CB350
1974 Honda CL360
Using Tapatalk
« Reply #6 on: May 15, 2014, 12:05:24 PM »
All done but now I'm stuck on adjusting the clutch. I get close and then POP! And I have to start all over again. Is there a trick that I'm missing?
1969 Suzuki M15-2
1971 Honda CB350
1974 Honda CL360
Using Tapatalk
Offline Johnie
« Reply #7 on: May 15, 2014, 09:02:28 PM »
Have tried www.hondawins.net  Lots of stuff over there about the clutch. Go to 350 engine section and do a search under clutch. There is a lot of stuff there. Good luck with it.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
fendersrule
« Reply #8 on: May 15, 2014, 10:25:03 PM »
Please explain your issue. I don't understand "I get close and pop!"
Did you insert the correct end of the clutch rod?
Clutch adjustment is a three part process: adjustment and helix nut, and both ends of the clutch cable.
Quick and dirty approach:
Screw clutch cable adjuster on handlebar halfway in
Loosen 10mm bolt on sprocket cover
Turn helix screw until resistance is felt, then back off a HAIR smidge
Tighten 10mm bolt
Coming from a bent rod to a new one, it's a guarantee that you'll need to do the above. More in depth process documented on the twins forum, but the above should work.
« Last Edit: May 15, 2014, 10:27:12 PM by fendersrule »
Offline MoMo
  • Ride like you're invisible
« Reply #9 on: May 16, 2014, 04:30:22 AM »
seems as though you may be missing the little ball that goes in the actuator
Offline grcamna2
« Reply #10 on: May 16, 2014, 07:59:35 AM »
I was thinking that also
fendersrule
« Reply #11 on: May 16, 2014, 08:09:29 AM »
If he is missing the ball, then he may have already destroyed the clevis.
« Reply #12 on: May 17, 2014, 09:15:36 PM »
It doesn't look any different than before when the clutch was functioning with the bent rod.
I'll take it apart and compare it with the cl360 that I have.
I've been following the adjustment procedures but it just ends with that pop sound and then the resistance on the clutch lever goes slack.
Like I said. I'll take apart the actuator and
1. Check for the ball
2. Check for any warpage or damage
3. Clean it up and grease it up and try again.
I would have left the bent rod in but I was just leaking oil all the time.
At least I've taken care of the leak.
1969 Suzuki M15-2
1971 Honda CB350
1974 Honda CL360
Using Tapatalk
fendersrule
« Reply #13 on: May 17, 2014, 09:19:23 PM »
Check for the ball. It commonly goes missing and it's a pretty big deal to have one!
Offline Johnie
Oshkosh, WI  USA
« Reply #15 on: May 20, 2014, 06:59:02 PM »
This may be part of the problem
Chipped and cracked.  Bummer.  Gotta find one now.
1969 Suzuki M15-2
1971 Honda CB350
1974 Honda CL360
Using Tapatalk
Offline grcamna2
« Reply #16 on: May 20, 2014, 08:32:47 PM »
Was the little ball in there ?
« Reply #17 on: May 21, 2014, 07:01:27 AM »
Yeah actually it was. After degreasing the whole unit is where I found the ball and the shears and cracks.
1969 Suzuki M15-2
1971 Honda CB350
1974 Honda CL360
Using Tapatalk
Offline grcamna2
« Reply #18 on: May 21, 2014, 07:11:33 AM »
Do you have to get an entire sidecover for that part ?
« Reply #19 on: May 21, 2014, 08:22:41 PM »
Yeah it's at the seat of the lever actuator thing
1969 Suzuki M15-2
1971 Honda CB350
1974 Honda CL360
Using Tapatalk
« Reply #20 on: May 22, 2014, 09:51:35 PM »
1969 Suzuki M15-2
1971 Honda CB350
1974 Honda CL360
A good welder can fix that: let me know if you can't find such a person. There's a good one here, $40/hr for that sort of stuff.
« Reply #21 on: May 24, 2014, 07:10:10 AM »
1969 Suzuki M15-2
1971 Honda CB350
1974 Honda CL360
Thanks!
I sourced a replacement for $20.
But yeah I considered a tig weld could take care of that.
1969 Suzuki M15-2
1971 Honda CB350
1974 Honda CL360
Using Tapatalk
« Reply #22 on: May 24, 2014, 04:34:50 PM »
Got the part, greased it up and adjusted a couple of times and I was back on the road. Thanks to all who replied.
1969 Suzuki M15-2
1971 Honda CB350
1974 Honda CL360
Using Tapatalk
« Reply #23 on: May 25, 2014, 07:35:04 PM »
The really cool thing is that now that I've replace the push rod, I found 5th gear!
1969 Suzuki M15-2
1971 Honda CB350
1974 Honda CL360
Using Tapatalk
