Progress has been slow and steady, whilst I waited for a few bits and pieces to come in the mail.
Started cleaning up the head, decided to do a little work on the ports. Exhausts ports got a clean, and some smoothing out of the casting marks around the valve stem guide boss.
Didn't reach touch the intake side, other than to smooth out some very obvious casting marks, and to match the intake runners.
The valves were pretty crusty, the exhausts in particular. Soaked them in diesel, then cleaned them up with the brass wire wheel on the bench grinder. The faces and the seats in the head looked OK, so I gave them a light lapping. Just enough that they had a clean, even ring, then reinstalled them, and checked they didn't leak, with some kerosene. All good.
Slightly chamfered the oil feel holes too.
I purchased a 650 camshaft to drop in, off another member. Checked it fitted, and didn't foul anywhere. Also got a used set of CB500 rockers & shafts, as a couple of my rockers were pitted. They were cheap, and I thought it would be good to fit the longer shafts, to hopefully negate any future wear of the rocker cover.
Then, whipped the valves out, washed the head in warm soapy water, dry it off, oiled the seats, and painted the head.
Reintalled the shims, new valve stem seals, and the valves. Gave them a whack with a plastic mallet&cloth, to make sure they were seated.
Head gasket got a light coat of Permatex Copper seal, installed new o-rings, and installed the head. Torqued it down, will probably back it off and re-torque again tomorrow. Starting to resemble a motor again...
