Author Topic: Could this be the cause of the metal in my oil pain?  (Read 560 times)
Offline arncruz
  • 1977 cb550
« on: May 09, 2014, 04:29:49 PM »
I was going through the parts of the engine when I saw this on the cam chain tensioner.  Is this normal wear and tear or is this a sign the cam chain is loose or not properly tensioned and should I get a new one (not cheap BTW!).  I also noticed a lip or ridge on one side of the center gear shift fork.  I included pictures of both.
My Stable
1969 CB750 #6xx
1969 CB750 #20xx
1969 CB750 #27xx
1969 CB750 #43xx survivor
1969 CB750 #12xxx
1970 CB750 K0 survivor
2014 MVP Agusta 675 F3
Offline LesterPiglet
  • 1977 CB550F2
Re: Could this be the cause of the metal in my oil pain?
« Reply #1 on: May 09, 2014, 04:33:07 PM »
The cam chain should never touch the metal of the tensioner. Either the tensioner was installed wrong or the chain was slack.
It shouldn't need replaced.
« Last Edit: May 09, 2014, 04:34:53 PM by LesterPiglet »
Offline arncruz
  • 1977 cb550
« Reply #2 on: May 09, 2014, 04:43:39 PM »
Lester, you think the tensioner should be okay then?  Should I change the Cam chain tensioner blade which is only $40 as oppose to the whole assembly which is over $200.
My Stable
1969 CB750 #6xx
1969 CB750 #20xx
1969 CB750 #27xx
1969 CB750 #12xxx
  • 1977 CB550F2
« Reply #3 on: May 09, 2014, 04:50:27 PM »
Yes, if the blade is worn replace it. You only need to change the tensioner if it doesn't work anymore.
« Reply #4 on: May 09, 2014, 05:56:43 PM »
Does look like a pretty funky area up at the top of the fork   ;)  Lets see what the 550 guys suggest as to the cause.
« Reply #5 on: May 09, 2014, 07:58:29 PM »
if the bottom of the tentioner has been miscued and missed its little locating well it will rub on the primary damper/starter clutch housing like this one has been.
