Author Topic: 1971 CL70 Project..... 117cc *Updates* and now a CL90, too!  (Read 19195 times)
Offline Scott S
Re: 1971 CL70 Project..... 117cc *Updates* and now a CL90, too!
« Reply #50 on: January 24, 2017, 04:44:44 AM »
 Here's a link to the place where the seller got the engine. This is exactly what I'll (probably) be getting for my '71 CL70.
http://www.pccmotor.com/li12moenwdru.html
 Does anyone know if the footpegs will work or will I need a spacer (seen that mentioned before)?
 Is that manifold long enough or will I need one of those 45 degree spacers to turn it?
 And...again... will that engine power lights? If so, what regulator will I need?
 *** dang it...new page. Please see the last post on page 2 ***
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline daniel9441
« Reply #51 on: January 24, 2017, 07:54:44 AM »
The Lifan engine should mount up directly to the 70cc Honda frame and foot pegs.
Also, here is a pic of my 70 ct90. I managed to blow up the supposedly bullet proof engine by seizing the oil pump....
Sent from my XT1585 using Tapatalk
« Reply #52 on: January 24, 2017, 07:59:04 AM »
Ever get your motor back from Terry at PFM?
Offline Scott S
« Reply #53 on: January 24, 2017, 08:06:14 AM »
 Nope. I gave up on it last year. Real fine human being....
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #54 on: January 26, 2017, 05:01:40 AM »
 Been talking to a guy on the LilHondas forum that's done this exact swap on a CL70. He says this seller has 12V bulbs that'll fit my headlight.
http://www.ebay.com/itm/360857466653?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
 He also uses this harness. Says it takes 15 minutes to swap and has all the right parts, connectors, etc. Makes it almost a plug and play swap.
http://www.ebay.com/itm/401262998525?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
 He uses the stock exhaust and says "Depending on gearing selection, you can hit 55+mph, but still lift the front end at the crack of the throttle in low & 2nd gear.".
'71 CB500 K0
'81 Yamaha XS650
