Author Topic: CB350F Brake Pedal Query  (Read 501 times)
Offline kingshax
« on: May 12, 2014, 02:10:49 AM »
Hi all,
Recently put a new exhaust on my '72 CB350F. Its a CB400F exhaust (from 4into1) and looks and sounds great with the Emgo Cafe muffler (also from 4into1).
My problem is that now the brake will not work (see pic below). There is no travel in the pedal because it hits the exhaust. I've tried adjusting it (the pedal) but that doesn't help.
Obviously i checked whether or not the 400F exhaust would fit the 350F, and having looked here and on dotheton, it was clear that the exhausts should be completely interchangeable.
Anyone had this trouble before?
Offline krusty
Re: CB350F Brake Pedal Query
« Reply #1 on: May 12, 2014, 02:37:25 AM »
The CB400F foot pegs are rear set, therefore the brake pedal would be positioned further back than the 350. This could be your problem
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Offline kingshax
« Reply #2 on: May 12, 2014, 09:31:20 AM »
I see. How would you go about trying to solve the problem?
« Reply #3 on: May 12, 2014, 09:50:50 AM »
how about using a 400f brake pedal?
Offline hoodellyhoo
  • CB350F
« Reply #4 on: May 12, 2014, 10:35:42 AM »
I don't know without looking  at pictures but you might be able to use a brake pedal from a 77 400f.
As said above the 75-76 400f had rear-set pegs so the brake pedal was farther back and higher up (and thus wouldn't contact the exhaust). The 77 400f had more standard foot controls like the 350f while retaining the same exhaust system as the earlier 400's. So I guess your options are to fab custom parts, use stock 75-76 400f foot controls, or see if possibly a 77 400f brake pedal will work.
Offline kingshax
« Reply #5 on: May 12, 2014, 01:05:59 PM »
Thanks for the help all. hoodellyhoo i will look into the different pedal options from the CB400's. Will report back once something is sorted.
