Author Topic: Gas / Cam-2 etc race fuels  (Read 625 times)
Offline jamesbekman
« on: May 12, 2014, 08:37:14 AM »
Hi Everyone,
Im just wondering if anyone is using Cam-2 in their bikes, if anyone has used the leaded or unleaded versions to keep their carbs from gunking up from the methanol in todays standard pump gas.
Offline Bodi
Re: Gas / Cam-2 etc race fuels
« Reply #1 on: May 12, 2014, 12:13:45 PM »
It's ethanol in pump gasoline, usually 10%. Methanol is what's in gas line antifreeze (and used as fuel in some race bikes and race cars).
If you can't find any ethanol free gasoline (and it's getting harder) then using" racing fuel" is an option but damn it's expensive. Plus what happens when you ride more than half a tank from home? Sometimes you can find ethanol free gasoline at marinas, always at airports but getting an airport fuel supplier to fill up your bike will be a trick.
Technically it's illegal to use racing fuel or avgas on public highways but I don't believe anyone is checking.
There are lots of instructions online for removing ethanol from pump gas, this would be way cheaper than buying racing fuel by the jerrycan. But... I would avoid messing with gasoline that way on a regular basis - it's just too dangerous.
« Reply #2 on: May 12, 2014, 02:12:27 PM »
Race gas is more stable, a shop I go to uses it in anything that will be sitting around a while. I've used it in my bikes with no problems. It burns slow, not sure if it might blue a pipe or not.
Right now the race car has an exotic oxygenated fuel (VP Q16) so the bike gets none of that.
