Author Topic: Does anyone have a pic (pref with measurement) of the this broken tab? K0  (Read 1004 times)
Offline Thunder
Hi guys, well i'm going to send this off for sandblasting before etch primering it and would like to fix the Tab up before spraying it.
now i have no idea that this is the swingarm meant to be with the frame (K0) but the metal chain guard(from a K4) does not line up so i am assuming it's the correct swingarm.
Unfortunately i don't have a plastic one to check what height the hole on the tab should be or even what it should look like so if anyone has some pics and measurements it would be a great help.
Thanks guys
Thor
Offline Johnie
Here are a couple pics of the swingarm area on my 12/69 KO. The bolt bracket at the back is 1 7/8ths long.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Thunder
Thank you so much. Ok it seems i have the wrong swingarm... bugger.
 :P
Offline Johnie
That spacer in the pic is designed to keep the plastic chain guard spread so the chain does not contact it. Here is a pic of the OEM chain guard for the KO.
Oshkosh, WI  USA
Offline Thunder
Gotcha, tx mate ;D
Well until i can find both swing arm and chain guard and find the cash, i'm going to put a later year one on with a metal guard.
tx again
Thor
Offline Johnie
Perfectly acceptable :)
Oshkosh, WI  USA
