Author Topic: Paint bubble/blister  (Read 604 times)
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
« on: May 12, 2014, 06:08:53 PM »
I now have a quarter sized blister around the gas cap on my tank and it's getting bigger. If I put a small hole in it with a pin vice, would that stop it's growing? I assume there is pressure causing it to expand. Anyone know. I know I can't fix it but maybe I can slow down the growth. I'll repaint it at some point but would like to know what's causing it so it doesn't do it again.
Offline new2bikes-again
    • wellandpond.com
Re: Paint bubble/blister
« Reply #1 on: May 12, 2014, 06:56:11 PM »
Do you mean under the paint? If so, yes I have that. When I was painting my tank last summer I Wet sanded deep enough to hit all the bondo and body filler. I washed it, put it in the sun for a few hours and started painting!
When these "warts and blisters" started popping up all over the tank, I posted some pictures. A few members on here explained that you can not get body filler wet. It holds moisture. It gets out later.
I popped a few of them and they turn yellow on the white. If you don't they stay about the same size.
