Author Topic: Adjusted my 750 cam chain tensioner and made a video.  (Read 3626 times)
Offline Jayelwin
« on: May 13, 2014, 09:17:23 AM »
Hey why not. iMovie on the phone makes it so easy. My apologies if this is too simple stuff.
Offline bjbuchanan
Re: Adjusted my 750 cam chain tensioner and made a video.
« Reply #1 on: May 13, 2014, 09:33:41 AM »
Nice
It gives a good tip for moving the 15 degree mark. It is usually a fuzzy description, everybody usually talks about it a little different
« Reply #2 on: May 13, 2014, 09:38:23 AM »
Yep...good work!
Vid shows how easy it is to do.
(Assumption is made though, that the tensioner mechanism is not stuck in its housing.  Removal, as mentioned, for cleaning and lubing is suggested if its never been done.)
Offline Jayelwin
« Reply #3 on: May 13, 2014, 10:43:54 AM »
Definitely remove the housing. Mine has to come off soon to get to the starter motor. Just wanted to be sure I could then adjust it once I put it back on.
« Reply #4 on: May 13, 2014, 11:06:22 AM »
Yep...good work!
Yes, very good vid. Good idea to remove it for cleaning and checking, if not known to be good otherwise.
One shortcut is to stick a small screwdriver or short end of an Allen wrench in the hole. Then when you loosen the lock bolt, you'll feel the plunger jump forward into the chain. Caveat: don't maintain pressure on the probe while re tightening the lock bolt. The plunger should be allowed to find itself without  help.
« Reply #5 on: May 13, 2014, 11:38:21 AM »
Then if you want to add more there is the dimple that wears into the adjustment shaft from people tightening the set screw too hard and every time you set it, it goes back in the dimple without adjusting anything. The dimples can be filed out if done carefully.
AJK
« Reply #6 on: May 13, 2014, 08:58:51 PM »
Very well made video. I would just add a small point, which is to ensure that you do not rotate the crank in the anti-clockwise direction at all during the process (especially just prior to the 15 deg angle).
  This is to ensure the timing chain is tight towards the front of the engine, and loose at the rear of the engine where the tensioner needs to take up its slack.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #7 on: May 14, 2014, 05:50:23 AM »
This makes it look very simple. I like that sewing machine of yours.
--Evan
1975 CB750K "Rhonda"
Offline iron_worker
« Reply #8 on: May 14, 2014, 09:52:12 AM »
Does it really matter if it's on #1 or #4 compression stroke? Either way, one of the cylinders will have their valves open and will affect the cam. I think the important part is the 15 degrees past TDC.
Just spitballin.
IW
« Reply #9 on: May 14, 2014, 10:20:23 AM »
Just spitballin.
IW
I do think it makes a difference for getting the cam chain at its slackest position. Manual seems pretty specific on that.
Offline lucky
« Reply #10 on: May 14, 2014, 10:28:14 AM »
http://www.youtube.com/watch?v=8841eO5tvro
Very good video .
Clear and concise and no heavy metal music. LOL..lol
And this procedure must be done before each valve adjustment.
Offline mec
« Reply #11 on: May 14, 2014, 10:36:21 AM »
why?
mec
Honda Monkey
Takeuchi TB 070
Massey Ferguson
Offline Johnie
« Reply #12 on: May 14, 2014, 11:20:31 AM »
Hey careful with that wrench man...you are marking up the starter cover :)
Agree...nice video and great sunflake orange there.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline tlbranth
« Reply #13 on: May 14, 2014, 06:09:05 PM »
Just spitballin.
IW
No it doesn't.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline Jayelwin
« Reply #14 on: May 14, 2014, 06:22:51 PM »
Haha, yeah. Was doing it one handed.
I'm going to try to paint the block and fins on bike and definitely replace that cover. It's the only one not shiny right now.
And yeah the FSO came out spectacular. Full five layer process. Wet sanded and buffed. And the stripes are painted on, no decals. Got a great paint guy.
Offline lucky
« Reply #15 on: May 15, 2014, 11:15:25 AM »
why?
mec
The reason is that when you adjust the valves the crank therefore cam must be in the correct position and if the cam chain is loose with too much slop it can cause the cam to not be in the correct position.
A small difference, but it does make a difference.
Offline D-Ral
« Reply #16 on: May 22, 2014, 03:50:49 AM »
Now make a video of you removing a cleaning the housing. Ha.
