Author Topic: oil filter install  (Read 2037 times)
ThomasJ
oil filter install
« on: May 22, 2005, 10:37:06 PM »
I took my engine out a while ago to have some work done on it and I can remember what order the oil filter, spring, and spacer go in. When I put the bolt through the case what part slides over the bolt first second and third. I dont have a manual yet so maybe sombody on here can help me out.
Thanks
Offline Clyde
Re: oil filter install
« Reply #1 on: May 22, 2005, 11:18:36 PM »
If you put the oil filter bolt through the casing, the order is spring,washer then the oil filter itself
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
Offline Raul CB750K1
« Reply #2 on: May 23, 2005, 12:43:49 AM »
Here you have the info for the CB750. I guess all are the same.
Regards
Raul
