Author Topic: Shifting Issue  (Read 1062 times)
Offline tortured soul
Shifting Issue
« on: May 14, 2014, 04:54:47 AM »
HELLO
I HAVE A 1978 CB750K I BOUGHT, IT SHIFTS THROUGH THE GEARS FINE UNTIL I START THE MOTOR WHEN ITS RUNNING IT WONT SHIFT UNDER A LOAD DOES ANYONE HAVE ANY SUGGESTIONS AS TO WHAT THE POBLEM COULD BE I JUST BOAGHT NEW CLUTCHES TO INSTALL HOPEING THAT WILL SOLVE THE PROBLEM THE BIKE DID SIT FOR YEARS IN THE GUYS GARAGE I BOAGHT IT FROM
Offline Vinhead1957
Re: Shifting Issue
« Reply #1 on: May 14, 2014, 05:10:05 AM »
Does the clutch release when you put the bike in gear and push it? ( not running ).  It could be not releasing
Re: Shifting Issue
« Reply #2 on: May 14, 2014, 10:05:54 PM »
 A dry clutch will do that, can you crank it over in gear with the kill switch off and the clutch lever in? It may jump foreward or it may break loose and oil the clutch.
Re: Shifting Issue
« Reply #3 on: May 21, 2014, 11:21:20 AM »
Thanks don I will have to try that hopefully that's all it is the motor uns so good and strong hate to think it may have to be ton down      Thanks Again  Mike
Offline bjbuchanan
Re: Shifting Issue
« Reply #4 on: May 21, 2014, 07:43:56 PM »
Its a sticking clutch. Pain until it frees up. I'm dealing with it with a red 400f I am resurrecting
Offline trueblue
Re: Shifting Issue
« Reply #5 on: May 22, 2014, 02:33:36 AM »
I had the same on my 650, I fired it up in neutral.  Pushed it up to jogging speed, jumped on and clicked it into 1st, pulled the clutch in, held the rear brake and kept revving it.  Doesn't take long to break free. ;D
1979 CB650Z
