Author Topic: Left switch issues (turn signal, horn, lamp)  (Read 448 times)
Offline doomsayer559
« on: May 15, 2014, 10:42:57 PM »
I have a 1976 CB550F and I cant seem to fund a switch assembly that is the same. I want to reuse the top section of my switch with the turn signal switch because it is still nice. The lower half has the mirror mount broken off from when my dad had the bike, probably happened in the late '70s. I have one used section from a 77 cb750, different, one from unknown year cb750 ( I guess they thre it in for free), and one from a 75 cb550 and it is different. It doesnt seem to fit to the top half of my switch worth a darn. And my old one has a very small notch for the neutral switch and the 75 doesnt. I dont think it sits in there completely flush without it. Hooked it all up any way and everything works but my turn signals. Only the rears blink and only about every 3 -4 seconds. Sorry for the lenghty post. I might add I reused my old switches which worked fime before I swapped the lower case.
Offline calj737
  • I refuse...
Re: Left switch issues (turn signal, horn, lamp)
« Reply #1 on: May 16, 2014, 05:17:26 AM »
I may have original sets from my '74 550. Can you post up a picture and I'll compare it for a match. If it suits, it's yours.
« Reply #2 on: May 16, 2014, 06:48:08 AM »
Yes I will open them up and post lics of them and how they are different. Im not sure why the '75 is differemt from my oe '76.
Offline calj737
  • I refuse...
« Reply #3 on: May 16, 2014, 07:04:30 AM »
Just pics of the housing top and bottom is fine. That'll help me confirm they're the same.
« Reply #4 on: May 16, 2014, 03:55:07 PM »
Well I seem to have gotten the signals working properly. I see the headlight bucket has to be mounted because of the gounds for the signals on the inside. I think im going to call it good for now, but ill keep you in mind if I have any further issues. Kinda served my own problem here lol but I have a few other things tonget wotking on asap
Offline calj737
  • I refuse...
« Reply #5 on: May 17, 2014, 05:18:54 AM »
Good enough. If you on do run into problems and need them, they're sitting on the discard pile (which means save for someone that needs them desperately).
