Author Topic: Reliability of compression tests on non running bikes  (Read 341 times)
Offline Prospect
« on: May 17, 2014, 05:11:52 PM »
I tend to do a compression test on potential bikes that I'm thinking of buying.  Some of them have set for a long time and I'm beginning to wander if the results I'm getting are reliable.  A compression test should be done on a warm engine so that's never an option.  Gauge error and other factors come into play.  I think a test will give you a very rough idea of the state of the engine.   Obviously if you get zero psi then you know what to expect but otherwise I don't usually use it as a predictable benchmark.  Usually also the pressure comes up once I get the bike running.
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
Offline Old Scrambler
Re: Reliability of compression tests on non running bikes
« Reply #1 on: May 17, 2014, 05:25:43 PM »
On post-60's bikes I like to see 75 to 90 lbs. and evenly across multis.  If not, I suspect a tear-down will be needed.  On motors out of the frame, I like to check the intake and exhaust ports for rust. I agree about the compression improving once running.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
