Author Topic: CB 350 rear wheel questions.  (Read 1010 times)
« on: May 18, 2014, 08:23:41 AM »
Anyone know axle size for CB750, and SL. Rear axles are they 18mm, or is one 17mm?
Anyone got a complete rear cb wheel with tire, sprocket,  drum, they can easily weigh?, can't pull mine off for a few more days.
Offline grcamna2
Re: CB 350 rear wheel questions.
« Reply #1 on: May 18, 2014, 11:54:40 AM »
754,
Do you want me to measure a CB350 twin rear wheel/axle ?
« Reply #2 on: May 18, 2014, 12:19:42 PM »
I looked around looks like they are all 17mm. Thanks, though.
Offline grcamna2
« Reply #3 on: May 18, 2014, 12:56:35 PM »
OK
Offline trueblue
« Reply #4 on: May 18, 2014, 06:43:25 PM »
You can change the bearings to get the correct axel size, I had to do this on my 350k2. I can't weigh the original wheel though, half of it has rusted away.
1979 CB650Z
Offline dusterdude
« Reply #5 on: May 18, 2014, 06:46:51 PM »
What tb said,when i put the cbr rear on my 750,i had to fuss with the bearings so the stock axle would work
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline tbpmusic
« Reply #6 on: May 19, 2014, 07:45:23 AM »
Try this, from my buddy Steve.......
http://www.hondatwins.net/forums/30-parts-guide/6-parts-cross-over-information.html
Bill Lane
« Reply #7 on: May 19, 2014, 01:39:00 PM »
Will make it simple
Got an OSSA wheel that weighs about 31 lbs,complete drum, sprocket,Akront shouldered rim, spokes, 4.00 tire and tube, axle.... If the 350 wheel weight 33 or more, it's not going on the bike..
