Author Topic: cb500 vscb550 carbs  (Read 827 times)
Offline 1stgenxxx
cb500 vscb550 carbs
« on: May 19, 2014, 07:42:38 AM »
What are the differences between the cb500 and cb550 carbs?
I'm putting together a cb500 but dont have a good set of carbs...seems 550 carbs are a lot cheaper and easier to aquire. I'm going to have to play with the jetting anyway due to air box and exhaust changes.
Offline Bankerdanny
  • Endeavor to persevere
Re: cb500 vscb550 carbs
« Reply #1 on: May 19, 2014, 08:05:30 AM »
Two Tired will weigh in on this I'm sure. But I am pretty sure you can use 74-76 550K and all year 550F carbs without any issues, although as you say you will need to adjust the jetting.
« Reply #2 on: May 19, 2014, 11:06:22 AM »
The carb bodies for 627B (cb500), 022A and 087A (Cb550K), and 069A (cb550F) are all the same casting with different internal parts (jetting).
Offline 1stgenxxx
« Reply #3 on: May 19, 2014, 11:58:11 AM »
Thats what I was thinking. looks like I will be going with the 550 carbs
Offline Kenzo1979
« Reply #4 on: May 19, 2014, 01:07:34 PM »
This is an interesting post to me because I have a K0 500 and a K0 550 that both have the 022A model carbs on them.  I know the 550 was completely stock when I bought it, but the 500 definitely had it's carbs changed at some point.  Could someone in this thread say what the proper jetting would be for 022A carbs on a 500?  Not trying to jack the thread, but it does seem relevant to your original question.
--Kenzo
** 71 CB500, 74 CB550, 76 CB400F, 77 CJ360t **
Offline Bankerdanny
« Reply #5 on: May 19, 2014, 01:59:51 PM »
The jetting should be whatever the book says it should be for a stock 500. The jets and needles are interchangeable between the carbs.
Offline Kenzo1979
« Reply #6 on: May 19, 2014, 02:03:44 PM »
Gotcha, stock jetting in the non-stock carbs, cool.
--Kenzo
Offline Kenzo1979
« Reply #7 on: May 19, 2014, 02:13:29 PM »
After searching the forum, it seems that the jetting is the same anyway;  100 mains and 38/40 slow.  That makes me feel better.
--Kenzo
« Reply #8 on: May 19, 2014, 02:19:31 PM »
No, it isn't the same.  "Jetting" includes the slide needle size, taper, and position.  And, #38 is different from #40.
But, I guess it is all the same if "running" means the same as "running well".
Offline Kenzo1979
« Reply #9 on: May 19, 2014, 02:26:04 PM »
Yeah, you're right.  I wish This was posted 2 months ago when I had both sets of carbs pulled.  But I will be investigating this closely the next time I pull the 500 carbs.  Thanks for the insight.
--Kenzo
