Author Topic: Checking oil 550f  (Read 1279 times)
Offline Wollongongwolf
Checking oil 550f
« on: May 21, 2014, 05:31:48 AM »
This should be easy to answer I hope. Want to check the oil level on the bike. Usually on my bikes, unscrew the cap when bike is warm, place dip stick back in , check level.
As I did about 100 kilometres after  changing oil and hitting the road for the first time,so went to check oil level, did it the usual way, cap resting on top, no oil on the stick, so screwed it back in , took it out and full.
 So take the level with cap screwed in or just resting on the top? Hot or cold, warm after resting for a few minutes or 10?
Advice please, sounds simple, but does not tell me in my manuals.
Thanks
Suzuki DRZ400
1976 Suzuki TS400
1984 XL350R
1976 CB550F Super Sport
Offline goldarrow
  • one day, i'll be an
Re: Checking oil 550f
« Reply #1 on: May 21, 2014, 06:10:05 AM »
After a ride, bike on center stand.  Go grab a cold beer, come back and check the the stick resting, not screw into the clutch cover.  Have some more beer
CB550 K0
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #2 on: May 21, 2014, 12:08:30 PM »
Exactly!  :D
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
« Reply #3 on: May 21, 2014, 01:16:43 PM »
Ok thanks, is that one beer before the check? If so what size? Is the speed of drinking affected by thirst or the heat of the day? You have now made this very complicated! Should I drink tea before midday?
Now you have me confused!
Suzuki DRZ400
1976 Suzuki TS400
1984 XL350R
« Reply #4 on: May 21, 2014, 01:51:09 PM »
You don't have the owner's manual?
Offline goldarrow
« Reply #5 on: May 21, 2014, 03:59:08 PM »
need a manual for this?!?! :o :o ;)
CB550 K0
« Reply #6 on: May 21, 2014, 04:46:32 PM »
Have original owners manual and two workshop manuals. I know how to check oil, but was not sure on this model if you check with it screwed in or resting on the case. It says to check the oil level, but not exactly the procedure.
It does not cost to double check with the experts. It would seem I got the answer to the oil, but not the drinking part. ;)
Suzuki DRZ400
1976 Suzuki TS400
1984 XL350R
« Reply #7 on: May 21, 2014, 04:59:49 PM »
The owner's manual does state the procedure.
Offline Thamuz
« Reply #8 on: May 21, 2014, 06:35:19 PM »
Must be not enough beer before reading the manual?  lol j/k :D
1979 Yami Chopper XS1100s
1978 CB750k
1977 CB550F
1974 CB550k
Parts bike for the 550's
« Reply #9 on: May 22, 2014, 03:44:35 AM »
I do have the manual and to the doubters, have included copy of such. As you will see, my information is different to yours. I do appreciate the advice given, but ain't no dumb Aussie Cretin. I does talk English proper sorta cobber. ::)
Suzuki DRZ400
1976 Suzuki TS400
1984 XL350R
« Reply #10 on: May 22, 2014, 09:29:30 AM »
Lost in translation.
Offline wardenerd
  • '77 550F '81 650C
« Reply #11 on: May 22, 2014, 11:45:46 AM »
When putting oil in a 550 several of the 550 owners on this forum have experienced oil leakage when the bike was filled to the full mark or overfilled.  The leaking in my bike stopped when I began filling the oil to just under the full mark.  If mine is not full it will not blow oil out the top of the cylinder.  Overfill and oil comes out and migrates past the openings where the plug on the left outboard cylinder sits.  It then gathers on the top fin and will eventually make a trail on the motor.
« Reply #12 on: May 22, 2014, 01:23:16 PM »
My bike did have oil in that area when I got it,  I will keep this in mind. Done a couple hundred kilometres and waiting to see if the oil reappears.
Thanks to all posts, basic question, but the things you pick up are so important.
Suzuki DRZ400
1976 Suzuki TS400
1984 XL350R
