Author Topic: 750 HYDRO CLUTCH..................pics added  (Read 1327 times)
Offline KRONUS0100
  • MAD MATT THE MANIAC
« on: May 21, 2014, 05:51:44 AM »
I know some others have done this, even a dry clutch here an there.  what are you using for a master cylinder and what are you doing with the existing clucth lever and switches in the left hand housing?  I currently have mine mocked up, and am having issues with the darned thing building pressure, currently have lever tied down to handlebar grip.  in a bit of conundrum about what to do about the left hand switch housing..............................the horn/hi-lo beam/blinkers  are in this housing.
will try an get some pics later this afternoon of where i am at with this.
« Last Edit: May 21, 2014, 07:20:58 AM by KRONUS0100 »
MATT
Offline dusterdude
Re: 750 HYDRO CLUTCH..................pics added
« Reply #1 on: May 21, 2014, 01:35:54 PM »
Curious,what are you using for a slave/actuator assy and for bleeding,get yourself a brake system syringe and hook it to the slave cylinder and push the air back thru the master cylinder
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline locomonza
« Reply #2 on: May 21, 2014, 01:41:19 PM »
for the switch I used the cb750 automatic switch. its the same with out the clutch, by the way if you need one I have one in perfect condition for sale.
Offline KRONUS0100
« Reply #3 on: May 26, 2014, 11:52:05 AM »
the slave cylinder is a vf750 sabre.  the master is a 83 nighthawk cb650sc.  have obtained a clutchless left hand switch.  whole project kinda on hold for moment now, had farm emergency come up.  will get back to it soon i hope.
MATT
« Reply #4 on: May 27, 2014, 04:19:28 AM »
Remove the slave cylinder and push in the piston. Reinstall and try bleeding again. i have had to do this on my FJ1200 and other hydraulic clutch set ups in the past.
