Author Topic: Front brake Calliper Cb750 k1  (Read 743 times)
Offline cakey
  • 5% recipe and 95% process
« on: May 21, 2014, 03:49:55 PM »
I have started to put my refurbished front brake calliper back together and noticed that there was no part no 16 as in the parts fiche. Is this a concern. Also when I got the old pads out there was no screw in the top of pad A or part no 5. The new pads I got have a metal screw in the pad. Is it to line up with the groove in the calliper?
1971 CB750 K1 (restored)
1975 GL1000 Goldwing (restored)
Offline dusterdude
Re: Front brake Calliper Cb750 k1
« Reply #1 on: May 21, 2014, 05:26:26 PM »
16 appears to be the dust boot,its nice to have but not mandatory.as far as the rest,im not sure
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Johnie
« Reply #2 on: May 21, 2014, 06:49:10 PM »
They call it a "seat". If I recall it is a plastic piece. I thought is was to seat the pad and help reduce brake chatter.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Thamuz
« Reply #3 on: May 21, 2014, 07:28:16 PM »
yeah, that's all 16 is.  A ring of plastic to reduce the noise level.  I lost mine, and it just makes a little more noise.
not really important. lol
1979 Yami Chopper XS1100s
1978 CB750k
1977 CB550F
1974 CB550k
Parts bike for the 550's
« Reply #4 on: May 21, 2014, 07:52:34 PM »
That is a domed steel "cap", that fits into the end of the piston. The domed end contacts the back side of the pad. I've got pics somewhere of my K1 calipers....
Offline cakey
« Reply #5 on: May 21, 2014, 07:55:45 PM »
Anyone know about the screw?
« Reply #6 on: May 21, 2014, 08:02:42 PM »
Yes, the screw fits into the groove in the caliper.
« Reply #7 on: May 21, 2014, 08:08:09 PM »
+1...Honda calls it the Pad seat.  You need it.
http://www.westernhonda.com/fiche_section_detail.asp?section=4326575&category=Motorcycles&make=Honda&year=1971&fveh=190504
Offline cakey
« Reply #8 on: May 22, 2014, 12:48:08 AM »
Thanks everyone,
I've ordered new bleeder screw and cap as well as the pad seat. Can anyone confirm if you just screw the screw into the pad until it just fits in the groove. I don't really see the point of the screw but I am sure as with 99.9% of Honda stuff that there's a reason for it.
« Reply #9 on: May 22, 2014, 03:42:57 AM »
Yes, you just screw it in, I used screw from old pad in a new pad at least once when the new one came without it.
The screw itself has a big head - the size of the groove  - it is not just regular Home Depot piece.
Offline cakey
« Reply #10 on: May 22, 2014, 05:48:46 AM »
Thanks mate!
Offline Henning
« Reply #11 on: May 22, 2014, 08:05:18 AM »
If you don't have the screw, the pad will spin and wear the inside of the caliper.
71 or thereabouts 750 K1 - this one should have been put down
Offline cakey
« Reply #12 on: May 22, 2014, 02:05:47 PM »
Ah ha! Thank you
