Author Topic: Rear tire removal  (Read 2193 times)
Offline dgilling
Rear tire removal
« on: May 22, 2014, 03:47:53 PM »
Any tricks to getting the rear tire off? This beast is on there good.
Offline goldarrow
  • one day, i'll be an
Re: Rear tire removal
« Reply #1 on: May 22, 2014, 03:50:20 PM »
Take it to tire shop and have it dismount $10
CB550 K0
Offline Patrick
« Reply #2 on: May 22, 2014, 04:51:59 PM »
Is it stuck at the bead and you can't get it loose or are you unable to stretch old rubber over the rim?
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
« Reply #3 on: May 22, 2014, 04:53:45 PM »
Cut that sucker off
Offline Patrick
« Reply #4 on: May 22, 2014, 04:56:54 PM »
Sometimes that is the only answer....
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline MoMo
  • Ride like you're invisible
« Reply #5 on: May 22, 2014, 05:48:47 PM »
$10 ???   Not around here
Offline Rodger
« Reply #6 on: May 22, 2014, 05:58:09 PM »
Agreed, check CL we have several guys in my area that do mounting and balancing out of there garages.  I've had all mine done this way, just got one installed last weekend.  $20 off the bike to pull old tire off, mount and balance new tire.  Super nice guy had nice equipment too.  MAC compressor  and a really nice tire machine. Retired mechanic from Rousch Racing so he had all the good tools and tool boxes!  For $20 its a no brainer.
« Last Edit: May 22, 2014, 05:59:57 PM by Rodger »
69 Honda CB350, 71 Honda CB350K, 72 Honda CB350K Café,
75 Honda CB400F Blue, 75 Honda CB400F Red 73 Honda CL175 and 76 Honda CJ360
Offline goldarrow
« Reply #7 on: May 22, 2014, 05:59:10 PM »
Yup. These guys  http://www.mctireworksinc.com dismounted my tires. Just had my 750F tires removed from Morris mag.  Didn't want to risk the wheels by cutting them nor spend 3 hours wrestling with old tires
CB550 K0
« Reply #8 on: May 22, 2014, 06:28:15 PM »
Agreed, check CL we have several guys in my area that do mounting and balancing out of there garages.  I've had all mine done this way, just got one installed last weekend.  $20 off the bike to pull old tire off, mount and balance new tire.  Super nice guy...
Same here.  He even has a K6 sitting covered outside his garage that I plan to rescue.
Offline dgilling
« Reply #9 on: May 23, 2014, 08:44:29 PM »
Eventually got them. Front really wasn't that bad but the back was insane. I think since they are tubeless rated that made them much harder to remove.
My new question is do I spend some time trying to get the rust removed from the inside of the rim if I'm going to get the wheels powder coated? I'm assuming they powder coat the inside of the rim too?
Offline lucky
« Reply #10 on: May 23, 2014, 08:53:26 PM »
When they powder coat they will strip them or sandblast them.
