Author Topic: CB350 twin has us perplexed  (Read 2360 times)
Offline Scott S
« on: May 23, 2014, 05:42:58 AM »
 Picked up a non-running CB350 a while back. A friend decided he wanted it and we got it running.
 I adjusted the valves and cam chain and cleaned the carbs using Simple Green/water, carb cleaner, compressed air, etc. I pulled all the jets and installed new O-rings. Diaphragms looked good. Trimmed the plug wires and installed new caps.
 Didn't really mess with timing or points.
 The bike ran but not so well. We noticed one pipe bluing and, on further inspection found that one carb wasn't acting right. One side was lean, the other rich.
 Pulled carbs and had them ultrasonically cleaned. Ordered genuine Honda O-rings. Set float height using the tube in the float bowl method. Meticulously adjusted cables, mixture screws, etc. Re-assembled and the bike is running much better and on both cylinders now. However....
 A fresh set of plugs and a plug chop showed us the same thing on the carbs; one side lean, one side rich.
 The plan now is to install a Pamco and probably new coils to eliminate anything electrical. We'll also check valve adjustment again....could bad valve lash cause something like this?
 We're using the old, stock air filters and they're not the cleanest, but we did blow them out with compressed air. Could they be the culprit?
 The bike is otherwise stock, except for the mufflers.
 Any ideas or suggestions are much appreciated.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline trueblue
Re: CB350 twin has us perplexed
« Reply #1 on: May 23, 2014, 05:49:07 AM »
First things first, I would chuck a new set of air cleaners on it. They may look ok but not pass enough air. Given the 350 twin has CV's on it blocked air cleaners can play merry hell on your mixtures.
1979 CB650Z
Offline Scott S
« Reply #2 on: May 23, 2014, 06:02:55 AM »
Forgot to mention: We replaced some cracked intake manifolds with good used ones.
The old plugs looked better and had started getting a little orange color, but that was mostly parking lot testing. Installed new plugs and did a proper chop, and you see what we got. It's almost like something is going on with the mains, but what/why?
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #3 on: May 23, 2014, 06:04:34 AM »
 I know it would be lean, but would running without the air filters briefly.....just to test that theory....be OK? Since genuine filters are so hard to find and very expensive, and not sure we want to get into pods...
'71 CB500 K0
'81 Yamaha XS650
Offline ohiocaferacer
  • www.OHIOCAFERACERS.com
    • OHIO CAFE RACERS
« Reply #4 on: May 23, 2014, 06:13:01 AM »
You can run the CB350 with open carbs and stock jetting.......wont be a problem.
It looks like that cyclinder isnt firing correctly.....your points may be bad or timing is off.
Offline tbpmusic
« Reply #5 on: May 23, 2014, 10:17:30 AM »
That's probably the issue - go to HondaTwins and read the procedure.
Bill Lane
Offline grcamna2
« Reply #6 on: May 23, 2014, 10:29:35 AM »
I'd make sure my emulsion tubes are tight in their bores and see to it that both primary and secondary main jets are sealed well at both their o-rings along w/ making sure the leaf spring inside is putting even pressure on both main jets.How does your pilot jet system operate? does she idle smoothly on both sides w/ clean even response from 0-1/8 throttle ? I imagine you've check out the floats/needles
Offline Scott S
« Reply #7 on: May 23, 2014, 10:53:22 AM »
 The mains are tight with new O rings. Isles well on both sides and mixture screws have an effect. Floats were set and checked using the tube on the float bowl method.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #8 on: May 23, 2014, 10:58:31 AM »
 This procedure?:http://www.hondatwins.net/forums/50-electrical-discussion/23580-how-time-honda-twin.html
'71 CB500 K0
'81 Yamaha XS650
Offline tbpmusic
« Reply #9 on: May 23, 2014, 12:29:48 PM »
Yeah, that's it - it's a bit counter-intuitive, so I suggested you read it.
Gap the left, time it by turning the whole plate.
Then time the right by just adjusting the gap - you'll end up at whatever gap it is on the right.
Bill Lane
Offline Bill/BentON Racing
    • BentON Racing
« Reply #10 on: May 23, 2014, 02:38:44 PM »
+1 just did one yesterday, waiting on new filters, runs so good! Man they fun bikes, subdivision stalker! ;D yeh, time it just like he said, buzz box or light works great, then can check running with strobe, Bill
My model had no index mark?
BentON Racing Website
BentON Racing Facebook
Offline Scott S
« Reply #11 on: May 23, 2014, 03:09:05 PM »
 A friend stopped by the shop today (I was out) and adjusted the points. Not sure what method he used, but I'm getting reports that the issue is much, much better. Still needs to be timed.
 Who knew that points would make THAT much difference?
 Pamco on the way soon, so may wait until then to do timing.
'71 CB500 K0
'81 Yamaha XS650
Offline tbpmusic
« Reply #12 on: May 23, 2014, 04:03:22 PM »
Hmm, I think I did.....
Do the timing and get the bike running good BEFORE you put the Pamco on - one thing at a time is best.
Bill Lane
Offline tbpmusic
« Reply #13 on: May 23, 2014, 04:04:02 PM »
Gulp - that would make it tough.......
Bill Lane
    • BentON Racing
« Reply #14 on: May 23, 2014, 04:13:48 PM »
Could, but I cheated, looked in my old school manual, it's rt in the middle of the stator pack, the one @ 10:00. Couldn't see anything broken, first time Ive encountered no mark on ignition. Did run into early model VF500 Interceptors with no index marks on cam sprockets.That was fun! ;D Bill
Offline SF
  • I burn gas very well
« Reply #15 on: May 25, 2014, 04:53:33 AM »
Great looking bike nice condition, hope to get mine running soon. I'll be watching this one, thanks for posting
Sent from my iPad using Tapatalk
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
