Author Topic: #2 not firing....steps to take  (Read 1349 times)
« on: May 24, 2014, 07:20:24 PM »
#2 doesn't get hot. Just warm from the others. I  can grab the header when all others are scalding hot.  I just finished this rebuild.  Hone, re-ring, valves lapped.  Everything was tight and within spec as noted in Hondamans book.
#2 Plug sparks when held against the head, and Plug caps are all new, but #2 read @ 5.24
Swapped 2/3 coil wires.  #2 still doesn't get hot.
I meticulously cleaned my carbs, but will verify cleanliness and choke butterfly operation in the morning...
What else should I check.  Thanks.
Offline goldarrow
  • one day, i'll be an
« Reply #1 on: May 24, 2014, 08:49:18 PM »
Check the pilot jet again, try new spark plug.  I had new plug that was bad before.  Check plug wire is good, not internally broken. That's all I could think of right now
CB550 K0
Offline Jimsun
Re: #2 not firing....steps to take
« Reply #2 on: May 24, 2014, 08:54:35 PM »
I had similar issue with my cb550. The culprit for me was my emulsion tube being clogged. After i cleaned them, cyl 2 header is as hot as the others.
74 cb550
« Reply #3 on: May 24, 2014, 09:07:38 PM »
I will pull my carbs to verify, but I disassembled and cleaned them for winter storage, and recently put them all back together.  They were still spotless and shiny.
Clean filtered gas, too.
Offline goldarrow
« Reply #4 on: May 24, 2014, 09:14:36 PM »
On a 750, just drop the bowls and see the jets
CB550 K0
« Reply #5 on: May 25, 2014, 05:20:03 AM »
A bad plug can still get spark when just laid on the head but may not work correctly under full compression.
Offline Vinhead1957
« Reply #6 on: May 25, 2014, 06:17:57 AM »
+1 on ekpent
« Reply #7 on: May 25, 2014, 06:42:18 AM »
Ok. I'll try this first, but I gotta wait till the neighborhood wakes up ::)
« Reply #8 on: May 25, 2014, 08:31:10 AM »
+1 on ekpent
+1....time to wake up the neighbors
« Reply #9 on: May 25, 2014, 09:45:40 AM »
#2 still cold with new plugs.   :-\  Carbs coming off for a re-check
Other ideas welcome and appreciated.....
Offline Tetter
  • CB500F Café - CB750F K6
« Reply #10 on: May 25, 2014, 10:09:59 AM »
As mentioned above... pilot jet.
I had the exact same issue after my rebuild.  :o
« Reply #11 on: May 25, 2014, 10:30:39 AM »
Hope that's it. Meticulously going thru mine...again  ::) ;D
« Reply #12 on: May 25, 2014, 10:50:15 AM »
Sometimes the float valves stick, starving the bowl for fuel.  Check the drain screw for #2.  Tap on the bowl to see if mechanical shock will dislodge the float/valve.
Or remove the carbs...
Offline jamesb
« Reply #13 on: May 25, 2014, 11:52:10 AM »
Mine was just doing that but on #1. I changed plugs wires  he ked everything then finally dropped the bowl on that carb to see I there was a problem and low and behold it must have been because it hasn't had any problems since. So I'm thinking it washed some debris out of there
Offline fire113
« Reply #14 on: May 25, 2014, 12:16:07 PM »
...check the vacuum screw at carb #2
« Reply #15 on: May 25, 2014, 12:20:36 PM »
Ok. Still not firing on #2
Each carb was inspected, broken down and reassembled.
No blockages in any of the jets.  Passages blown clean. Float heights verified correct.
Carbs back on bike....Bowl drain screw on #2 opened allowing gas to flow.
When tightened, float valve shut off fuel.  Carbs are operating as they should as far as I can tell.
Next option.... :-\
« Reply #16 on: May 25, 2014, 12:22:25 PM »
Ok...
« Reply #17 on: May 25, 2014, 12:28:54 PM »
« Last Edit: May 25, 2014, 12:33:07 PM by flybox1 »
Offline fire113
« Reply #18 on: May 25, 2014, 12:50:32 PM »
...try a shot of start pilot spray at carb #2 to be sure that something explosive is in cyl. #2 and see if pipe #2 is getting hot. If not do a compression test on cylinder #2.
« Reply #19 on: May 25, 2014, 12:52:16 PM »
  Do the plugs get wet after cranking with full choke and the kill switch blocking spark?
Inspect the valve operation through the inspection/adjustment ports, verify they all move full travel.
Compression check.
Fuel/air, compression, spark = must run.
« Reply #20 on: May 25, 2014, 02:13:58 PM »
Compression check.
Exactly...so, I pulled the new densos I put in this am, and im pretty damn embarassed ::) but I'll post here and take my lumps.    ;D  I added four 1" screened airbox powerholes and I didn't account for this change.
Holy isht those are lean  :o
After going out 2 turns on my mixture screws, they are just starting to tan. And #2 is warming up.  Certainly not hot like the others, but noticeably warmer after 2-3 min idle.
#42 pilots are on order...
Thanks for the input guys.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #21 on: May 25, 2014, 07:11:58 PM »
Hey Rob, it wouldn't be a good story without a few bumps along the way ;)
I would throw the ND plugs in the trash and go get some NGKs. I had the same problem earlier this year with 550F. It was  bad plug and it was fairly new.
Also:
Did you recheck your valve tappets? Maybe #2 is too tight? No comp, no fire.
Are you sure you have OEM spec pilots? I had that same problem as well with the F.
I hope you get it on the road soon, but today is a good day to wrench in a nice dry garage.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline disco
« Reply #22 on: May 26, 2014, 01:51:54 AM »
+1 to what Fire113 said.....a bit of starting fluid thru the carby will firstly determine whether your problem is fuel or spark. Then tackle the problem once you have narrowed it down.
1976 CB750 K6 Sapphire Blue
1972 CB750 K2 Candy Red
1972 CB750 K2 Candy Gold'
