Author Topic: Tacho/Speedo rebuild.  (Read 383 times)
Offline Paul Lowe
  • If you like then it is good...
« on: May 24, 2014, 08:12:07 PM »
Hi. I am in the process of rebuilding my gauges and do far so good. Gauges apart and happy.
Before I reassemble I want to 100% sure I don't need them apart again!
I do not know the history of the gauges but have been assured by PO they are fine.
Questions:
1 is the oil only for dampening or does it cause gauge to work
2 Or is gauge magnetic driven and oil only dampening.
3 what speed does tacho and speedo actually turn at to give full deflection?
4 where is my 10mm ring spanner...
Thanks in advance.
Paul
My Honda sickness deepens
CB350F 1972
CB360G 1974
CB750 K1 1971
CT90 K0 1968
C102 1963
C50 1968
C70 1972
C90 1974
CL90 1968
1/2HP electric bike home made...
AJK
Re: Tacho/Speedo rebuild.
« Reply #1 on: May 25, 2014, 12:55:17 AM »
Hi Paul,
(1) Oil is for the dashpot and only for damping. No oil just means that the tacho needle may bounce around a bit. The oil/dashpot acts as a signal filter, thus smoothing out any oscillations in the needle.
(2) Yes, it is magnetically driven from what i can tell.
(3) There should be some calibration numbers stamped on the gauge housing. Like 60kms/hr is xx rpms or something to that effect.
(4) Where you put it last
This page may end up being useful to you
http://www.salocal.com/sohc/tech/speedo/spedo1.htm
I forgot to add, DO NOT get oil on that magnet!
« Last Edit: May 25, 2014, 12:57:16 AM by AJK »
