Author Topic: CB650 charging issue... help!!!  (Read 3773 times)
Offline iron_worker
Re: CB650 charging issue... help!!!
« Reply #25 on: May 30, 2014, 11:06:34 AM »
Well if the bike is running too hot you'll likely feel the heat coming off of it when stopped... probably will creak a lot when you stop and it starts cooling off. It will probably also feel like i'ts running too rich as the fuel atomizes better when it's heated in the intake tracts so you need less of it (although if it's running hot due to a lean condition ... which is most likely then this probably won't happen).
It's tough to tell without actually measuring the head temp or oil temp while it's running correctly so you have a basis of comparison.
IW
« Reply #26 on: May 30, 2014, 12:01:16 PM »
I agree, it doesn't appear you have a charging issue.
Really the only way to isolate the "no-start" problem, is to either measure the current draw of the starter.  (25-100 amp test equipment capability.)
Or, have the battery load tested (check for amperage supply) to see what it can sustain under load.  Stock battery should supply 225 AMP or more without dipping the voltage below 10V.
If the motor draws too much for a good battery to supply, then fix the motor.  If the battery can't supply normal starter motor draw, then investigate why that is, either starter motor failure or engine too hard to spin over.  (Which is why I suggested pushing the bike while in top gear, as it is a no cost check.  If you had a kick start lever, you could check turn over resistance with that.)
Without testing, the other method is by substitution.  Replace battery, or starter motor, in turn to see what fixes the issue.  When problem abates, you found the fault!
Um, you did check the electrolyte level in the battery, didn't you?  I don't recall any mention of this.  But, it is generally the first thing to check when a battery is under suspicion.
Offline Saperlipopet
« Reply #27 on: May 31, 2014, 12:06:24 PM »
Going to check this asap!
Previous bikes
'81 CB650
'82 CB650
'81 CB900F
'75 CB360T
'78 CB750K
Current:
'78 CB550K
