Author Topic: After a rebuild how long until rings seat?  (Read 6737 times)
Offline ncstatecamp
Re: After a rebuild how long until rings seat?
« Reply #25 on: May 30, 2014, 09:46:47 AM »
The rings were all installed correctly. I quadruple checked that.
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #26 on: May 30, 2014, 10:43:48 AM »
I did the rings wrong once.....Then bought a nice big Magnifiying glass to see the darn lettering....I had the scraper ring going up instead of down. Was pissed but I did it myself, lesson learned..  :-[
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline iron_worker
« Reply #27 on: May 30, 2014, 10:50:42 AM »
Some rings (Ie the ones I got from Cycle X) are square cut and don't have an up and down. You just put the chrome one in the top groove and you're good to go.
IW
« Reply #28 on: May 30, 2014, 02:35:03 PM »
Dave,
Have you scheduled the re-match yet ?  8)
itll happen!
Offline ncstatecamp
« Reply #29 on: May 31, 2014, 08:47:47 AM »
Luckily my eyesight up close is pretty damn good. The rink logo is up.
Wobbly
« Reply #30 on: May 31, 2014, 10:40:24 AM »
BIG +1 on PeWe's link !! Some may not agree, but I can see Mototune's line of thinking and will use his process on the next motor I build !!! Sounds logical to me.   ...cougar...
When BMW introduced the S1000RR at the end of 2009, engines were blowing up at an alarming rate. By the beginning of the next year, the new bikes came with an rpm limiter installed which was removed at the first service (600 miles/1,000km). Amazing that the clueless engineers at BMW managed to build the superbike of the year with unrivaled performance, but are so clueless regarding the break-in procedure. Pure coincidence that the measure worked fine, right?. But, then again, the RR is not such a modern bike as the CB Four which probably helps to explain the different procedures. Wait a minute? Wasn't it the other way around? Oh well. What do the engineers at BMW know anyhow?
Offline Lostboy Steve
« Reply #31 on: May 31, 2014, 11:28:16 AM »
Should I post that link again? The one about break-in procedures? Again, I don't know what to believe, but the link is a good one. Here:
[url]http://www.mototuneusa.com/break_in_secrets.htm/url]
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
AJK
« Reply #32 on: May 31, 2014, 06:35:02 PM »
Just some thoughts,
Load is more important than revs. When loaded, the combustion pressure gets forced behind the ring groove and forces the ring out which helps it mate the new ring surface to a freshly honed bore. You have a limited window in which to take advantage of this before you wear that ring in against the new bore/hone properly. Thats why its no good to let it sit there and idle on a fresh build, because all your doing is wasting the opportunity to make a good ring seal by wearing out the cross hatch you put in there in the first place for that very reason. You want to get those surfaces mating under load to get a good seal for a long time.
  On a new motor, everything is tight, so you need to keep the revs moderate to start with, but you have to give it load, so get climbing some hills. In doing so, you also need to keep temperature in mind because everything is going to run a lot hotter until its all run in due to increased friction, so after a short run, let it cool down again and repeat. After 20 to 50kms of riding, the piston has already gone up and down thousands of times, so you can imagine what its taken off the liners & ring surface in terms of shavings in such a short time on a fresh hone. You will see this as glitter (a lot of it) in your first oil change. Thats why its real important to change your oil and filter on the first change because the engine is spewing this stuff out. You will find this glitter in the oil, but also when you take your filter out, rip it apart and take a look at what you will find in the bottom of the v-grooves and also in the bottom of your filter housing cup. Get some between your fingers and give it a rub and you will quickly understand whats going on in your motor.
  As you start to put on more kms, continue to increase the revs. You will get more shavings, but they will be a lot less in quantity, even with more kms.
 As someone said, use cheap crappy mineral oil without friction modifiers for the first 1000 miles at least before going to something better. You want the surfaces to marry (with clean but crappy oil), then once thats done, put something decent in there. After a few several thousand kms, it would be good to pull the pan and clean the screen as well.
  Modern engines still are honed in the same manner, but these days they finish it off with a plateu hone which knocks off all the high peaks but allows good oil retention in the lows, making for a motor that requires less & quicker break in than a traditionally honed one. A few hard runs and its all done.
So the short of it is, think load first, then revs, and as it starts to free up after some kms, increase the revs and keep giving it more load at the same time.
The following pics (in this order) are:
(1) Filter ripped apart - have a look at the particles in the v-grooves
(2) same as (1) but reverse/clean side of the filter for comparison
(3) Cup housing.
All this happened in the first 20kms.
This is why I also like this idea
http://forums.sohc4.net/index.php?topic=103432.0
http://forums.sohc4.net/index.php?topic=137793.0
There are different schools of thought on the matter. These are just my thoughts & something thats worked well for me over the years.
« Last Edit: May 31, 2014, 06:48:51 PM by AJK »
