Author Topic: 72 CB350 Build For The Wife  (Read 68547 times)
Offline Harsh
  • 74 CB750 and two 72 CB350's
Re: 72 CB350 Build For The Wife
« Reply #100 on: August 13, 2014, 01:26:24 PM »
Broke the frame down today and removed all of the little parts and brackets from it.  When I went to loosen the nuts from the top triple I noticed a major problem on the right side.  It was cracked and when I removed the bolt holding it, it fell apart in two pieces.  So now I am in the hunt for another triple.
Offline SF
  • I burn gas very well
« Reply #101 on: August 13, 2014, 02:21:03 PM »
great build! glad your surgery went well and your back at the bike. I too lost all pics on tear down and your right the manuals are all missing the small details.
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
« Reply #102 on: August 13, 2014, 04:40:46 PM »
Anyone have a spare top triple for Harsh?
Offline grcamna2
« Reply #104 on: August 13, 2014, 05:57:35 PM »
Those can be hard to find.
Looks diff than the '71....
http://www.ebay.com/itm/1971-Honda-CB350-CB-350-H661-triple-tree-steering-stem-yoke-/350791056212?pt=Motorcycles_Parts_Accessories&hash=item51acc6bb54&vxp=mtr
Harsh,
I'm leaving tomorrow morning to go be a very small vendor @ a small vintage Japanese swap meet and I'll be there until Sun.   Do you want me to find one there for you? if so PM me and you can phone me and I'll find you one there.I went there 3 years ago and a guy I met who came in as a buyer knew I was looking for one so he went back home and got me one for a good deal.  ;)
Offline MoMo
  • Ride like you're invisible
« Reply #105 on: August 13, 2014, 07:36:10 PM »
Harsh,
You headed to White Rose Bill?  I may drive out Sat Afternoon....Larry
Offline grcamna2
« Reply #106 on: August 13, 2014, 08:09:15 PM »
Harsh,
I am Larry. I was there 3 years ago when I lived in Bethlehem and parked my old  Volvo right next to the tree at the creek & caught poison ivy  :o... This time I'll be getting there Thurs. late aft. and finding higher ground in case it rains  :) I'll be laying stuff down on a silver tarp on the grass. I hope to meet you there;it's small enough to be fun,a low stress weekend, you know ?
Offline Harsh
« Reply #107 on: August 14, 2014, 04:42:28 PM »
Met with Cal today.  He snagged my replacement head and is going to bead blast it then have his machinist do what needs to be done.  He also picked up a bunch of parts that attach to the frame that he is going to bead blast for me.
Since I can't do any engine work until I get the head back I figured I would get to work on the frame.  So I stripped it down to bare metal.  It was a bit of a pain because of little nooks and crannies, but I got it done.  There was a bunch of mouse fluff stuff on the inside of the frame, but I got it all out.
Offline SF
« Reply #108 on: August 14, 2014, 09:25:49 PM »
Actually looks good like that
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
« Reply #109 on: August 14, 2014, 09:46:20 PM »
I'd have to agree.  It might look good to just clear it the way it is!
Offline Harsh
« Reply #110 on: August 15, 2014, 05:42:26 AM »
Unfortunately, the wife isn't gonna go for that.
Offline edhaeuser
« Reply #111 on: August 15, 2014, 04:00:48 PM »
I have a 72 cl 350 carcass that has a top tree if you are not in a hurry for me to get it apart.  Looks the same as the pic.
« Reply #112 on: August 15, 2014, 06:56:28 PM »
Would look even better with an XR650 single thrown in there... ;D
« Reply #113 on: August 15, 2014, 09:40:20 PM »
XR650 aka Mr. Braaaaaap!
Offline Harsh
« Reply #114 on: August 16, 2014, 03:27:16 PM »
It was a bit of highs and lows over the past couple of days.  I cleaned up the frame a little bit (well a lot) more.  I took a wire wheel to it and removed any imperfections and gave it a bit of a tooth for the powder coat to grab a hold to.  Also spent some time sanding the rear brake plate and then I polished it up nice and shiny today.  Took the rear tire off the wheel and at some point instead of using a rubber strip to cover the spokes they wrapped a couple layers of duct tape over them.  Spent some time with the wire wheel on the inside to remove the glue and rust.  I will soak a towel in Prep-N-Etch and lay it over the inside of the wheel to take care of the rust.  It will take a bit working the towel around the wheel, but once done it should be just fine.
I pulled out the Japanese grease fittings to replace them with some standard zerk fittings.  I drilled out the holes in the swingarm pivot bolt, but when I went to tap them my bit broke.  I tried to get it out, but failed.  Luckily the SL350 I picked up from dusterdude uses the same bolt so I was able to swap them.  A new tap and some extra cutting oil and all is good now.
The rear wheel had the bearings replaced at some point with sealed bearings.  They spin nice and smooth so I thankfully don't have to mess with them.
Before
After
« Last Edit: August 16, 2014, 03:51:19 PM by Harsh »
Offline dusterdude
« Reply #115 on: August 16, 2014, 03:49:34 PM »
Im glad that pos was of some use to you
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Harsh
« Reply #116 on: August 16, 2014, 03:53:00 PM »
Me too. My heart sank when the tap broke.  All I initially thought was that I now have to hunt for another part.
Offline dusterdude
« Reply #117 on: August 16, 2014, 04:39:49 PM »
I understand that
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline Harsh
« Reply #118 on: August 17, 2014, 03:04:07 PM »
Not sure if this will show up well via pics, but in person you can really tell a difference.  I decided to try and document my polishing process a bit more.  All I did today was wet sand the part.  Tomorrow I will hit it with the buffing wheels.
Start:
After 320.
After 600.
After 1200.
After 2000.
« Reply #119 on: August 17, 2014, 03:08:31 PM »
Very nice!  Are you going to give it a go on the ribs??
Offline Harsh
« Reply #120 on: August 17, 2014, 03:11:19 PM »
Not sure what I am going to do in the middle.  Sanding/polishing them would be exceptionally difficult.  Cleaning the wheels on the 750 is a pain in the arse so I can't imagine trying to get in there occasionally with some metal polish.  I am thinking about hitting the middle with a brass wire wheel to clean them up and powder coating the middle whatever color I do the frame in.  That way a simple spray and wipe would suffice.
« Reply #121 on: August 17, 2014, 03:47:18 PM »
The PC will definitely be easier to clean than porous oxidized metal.  +++1
« Reply #122 on: August 17, 2014, 03:48:06 PM »
Looks real good, Harsh.
Offline Harsh
« Reply #123 on: August 18, 2014, 09:33:31 AM »
Wire wheeled the center part then moved onto the polishing.  Again, not sure if the differences will show up via the pics, but when looking at it in person you can see a change.
After black compound
After rouge compound
After green compound
Offline calj737
  • I refuse...
« Reply #124 on: August 18, 2014, 09:48:13 AM »
You must really love that bride of yours! Those hubs look extraordinary, Harsh. I should be back to you by Wednesday with a trunk load of goodies. Probably coming all the way down too.
TTYT
