Author Topic: 72 CB350 Build For The Wife  (Read 68571 times)
Offline grcamna2
Re: 72 CB350 Build For The Wife
« Reply #150 on: September 01, 2014, 05:04:48 PM »
Harsh,
Do you have an extra left sidecover? they always seem to crack right where those side vents are on the K4,of course it would have helped if I didn't pull my car up too close...  :o I park my cycle outside my apt. in the same space as my car in front of it as I'm  allowed only the one space so I park it the long way covered up. The work you've been doing on yours cosmetically is excellent and it certainly must have taken you many long tedious hrs. to accomplish.I hope your wife gets many good enjoyable miles from that 350  8)
Offline Harsh
  • 74 CB750 and two 72 CB350's
« Reply #151 on: September 02, 2014, 08:14:29 AM »
Harsh,
I thought I did for a bit.  I was trying to figure out where it came from...then it dawned on me.  It goes to my daughter's bike.
Offline grcamna2
« Reply #152 on: September 02, 2014, 08:17:01 AM »
ok
Offline Harsh
« Reply #153 on: September 02, 2014, 01:20:44 PM »
Well the brake fluid seemed to do the trick.  I let it sit over night and it bubbled up the paint fairly well.  The brown layer wasn't paint, it was body filler.  That stuff was very difficult to get through as was the second color the cover was painted.  Unfortunately, the not cracked covers I bought did have a crack in one of them.  It was right next to the tab.  I mixed up some Hysol and was able to get it inside the crack and made a nice support on the back side to help keep it from cracking again.  I will say using the brake fluid  is not clean in any way, shape, or form.  I used a razor blade to help scrape and slice through the layers of paint.  If I was a patient man I would put on a coat and occasionally re-apply more and just let it work, but I am not.  So I would put on a coat, work on something for a bit, then scrape, re-apply........After I was done getting the paint off I thoroughly cleaned them with some degreaser I get from work.
I cleaned, de-rusted, and painted the air boxes.  I know they will not be seen, but they are nice and clean looking now.
I have a set of each of these.  Which one is correct for a K4?  Neither set is in great condition and they both look like someone attempted to paint them, but didn't do a good job.  These are the better of the two.
Offline grcamna2
« Reply #154 on: September 02, 2014, 01:49:57 PM »
From memory the one on the left(I don't have the bike near me right now)is just like my K4.
« Reply #155 on: September 02, 2014, 02:12:33 PM »
Navy de-greaser.  I bet that's some potent stuff.  Apparently, the Navy used to dump that and aircraft stripper at El Toro MCAS for decades to the point it was poisoning the water table.  I bet it makes short work of baked on oil and grease on a crankcase!
Offline Harsh
« Reply #156 on: September 03, 2014, 03:05:37 PM »
When I closed down Cecil Field in Jacksonville, Fl the Navy was fined pretty heavily for all of the crap they dumped over the years.  The stuff I am using is actually designed to be much safer, yet actually work.  We use it in the scrubby machine that cleaned the floors in the hangar.
Well today was my first full day at work since my surgery and I must say i didn't like it one bit.  Not only was I not used to getting up at 0430, but I didn't get to spend nearly as much time working on the bike.  All I accomplished was sanding down the Hysol on the crack that was in the side cover.  It is nice and solid now.  I also picked up some Uni foam and adhered it to the screen.  Tomorrow after it is thoroughly dried I will adhere it to the covers.
« Reply #157 on: September 03, 2014, 03:31:55 PM »
Well today was my first full day at work since my surgery and I must say i didn't like it one bit.  Not only was I not used to getting up at 0430,  . . .
Isn't that 0 Dark Thirty?  I hate it when you get up and it's still pitch black.
Offline Harsh
« Reply #158 on: September 03, 2014, 03:34:08 PM »
Yep...been doing it for 24 plus years and it still sucks.
Offline calj737
  • I refuse...
« Reply #159 on: September 03, 2014, 03:36:23 PM »
Yeah but, no traffic, home early, and there's never a line at the drive-thru at that hour. Even the drunks have made it home by then.
« Reply #160 on: September 03, 2014, 03:42:12 PM »
The bummer is when the drunks have not made it home by then, but you can usually pick them out .
Offline bjbuchanan
« Reply #161 on: September 04, 2014, 02:19:21 PM »
The winter is what gets to me with the early rising. You go in and its dark and you get out and its dark. Depressing
« Reply #162 on: September 04, 2014, 02:34:42 PM »
Hate that, too.  04:30 sounds brutal though.
Offline Harsh
« Reply #163 on: September 04, 2014, 02:42:37 PM »
Had my follow up today.  Everything is going great and I have been cleared for pretty much everything.  Took some x-rays which I was able to get a copy of.
« Reply #164 on: September 04, 2014, 03:29:06 PM »
Harsh,
That doesn't look fun.  Did they go in from the front or back of your neck?
We can all see your fillings now!  Take care of those choppers!
Glad you are cleared for duty.  Hope the surgery helped.
Don
PS  Where's the GPS tracker they implant in you service guys? ;)
« Last Edit: September 04, 2014, 03:35:37 PM by CB750 Cafe Racer Fan »
Offline Harsh
« Reply #165 on: September 04, 2014, 04:17:22 PM »
They go through the front.  If there is a gps installed they aren't telling me where they put it.
« Reply #166 on: September 04, 2014, 04:42:32 PM »
Glad the surgery was successful.  Luckily, I dodged that bullet on my L4/L5/S1.
Offline grcamna2
« Reply #167 on: September 18, 2014, 07:27:46 AM »
How she going lately Harsh ?
Offline Harsh
« Reply #168 on: September 18, 2014, 08:29:35 AM »
Very slowly.  Work has been crazy since I am holding down two positions and had to put in a lot of work for the new Chief Petty Officer induction stuff.
I have been getting my butt kicked for a little over a week trying to true the wheels.  I am at the point that I am going to have the same guy true them that did the wheels on the 750.  Supposed to meet with my powder coater this week, but not sure if my work schedule will permit it.
Offline grcamna2
« Reply #169 on: September 18, 2014, 10:10:31 AM »
Harsh, if I was a little closer to you I'd come over and true them for you;I have a nice truing stand.
Offline calj737
  • I refuse...
« Reply #170 on: September 18, 2014, 11:41:02 AM »
Get on down there Bill, the beach is beautiful this time of year in the rates are much cheaper. i'll give you a list of great restaurants in the world's best donut shop to keep you fueled up while you true up the Chiefs spokes!
Offline grcamna2
« Reply #171 on: September 18, 2014, 05:01:19 PM »
That sounds like a plan  :)
Offline Harsh
« Reply #172 on: September 25, 2014, 07:16:35 PM »
This having to go to work stuff is really cutting into my available time.
I passed the wheel truing off to the guy that did my last set of wheels.  Since then I think I figured out what I did wrong so I will give it a go on the next bike.
I also dropped of a bunch of parts at the powder coater today.  They should be ready next week.  Once I get those back I can actually start assembly.
Offline grcamna2
« Reply #173 on: September 25, 2014, 07:51:02 PM »
Harsh, Good to hear from you again !
« Reply #174 on: September 25, 2014, 10:37:51 PM »
Looking forward to some more progress on this top shelf build.
