Author Topic: 72 CB350 Build For The Wife  (Read 68791 times)
Offline Harsh
  • 74 CB750 and two 72 CB350's
Re: 72 CB350 Build For The Wife
« Reply #200 on: October 21, 2014, 03:15:00 PM »
Well updates seem to be slower and slower.  I was recently given a promotion at work so my days are a lot more full.  I am now the Command Senior Chief for my squadron.
Anyway, I received and installed my new swingarm bushings.  I kind of wish they weren't covered up by the rubber covers because they look so good.
I was able to get the swingarm installed, the wiring harness, and a few other bits.
I have the lower triple and stem in the freezer so hopefully tomorrow I will be able to install the bearings.  However, I am a little concerned about the stack height.  When I measured the old set and the new set side by side (including seals) the new set was slightly taller.  From what I have read most people have to use one of the washers.  It doesn't look like I should have to use one at all.  I am worried about the headlight ears lining up correctly.
Offline grcamna2
« Reply #201 on: October 21, 2014, 05:45:04 PM »
Love those blacked-out and shined uniform cyl. & head fins Harsh !  8)
« Reply #202 on: October 21, 2014, 06:19:58 PM »
Congrats on the promotion.
You didn't measure the stack height?
Offline Harsh
« Reply #203 on: October 22, 2014, 03:02:17 AM »
I did measure them.  I had the old and new side by side.  The new (with seal) is slightly taller than the old (with seal).  I went off of that and installed the races in the frame.  However, I am now wondering if I should not have included the seals in the measurement.  Without the seals being used while taking the measurements the old set was slightly taller than the new set.
« Last Edit: October 22, 2014, 04:47:51 AM by Harsh »
Offline bjbuchanan
« Reply #204 on: October 23, 2014, 03:05:34 PM »
It's normally measured without the seal but a small amount in either direction really doesn't matter. Did you measure what the differences were or is it all eyeballed?
Offline Harsh
« Reply #205 on: October 23, 2014, 03:23:03 PM »
I laid a ruler across them and eyeballed the difference.  I am going to re-do the measurement.  It won't take much to knock out the race.  If I mess it up it is somewhat cheap to replace.
Offline bjbuchanan
« Reply #206 on: October 23, 2014, 04:44:12 PM »
I have swapped over when I screwed up before, its not too much. From what I have seen you have more than enough skill to carefully tap that sucker out of there. Don't forget that the kit already has a tolerance on it to begin with and it isn't super tight.
Offline Harsh
« Reply #207 on: October 26, 2014, 01:53:42 PM »
My lower back has been hurting pretty bad so my time working on the bike has been limited.  However, I finally received the LED headlight so I was able to install that.  I didn't follow the writeup on it as I elected to use the rubber strip that was in the sealed unit.  I put a thin bead of silicone in the corner of the mount then pressed in the rubber strip.  I then put a thin bead of silicone in the corner of the rubber strip then put the glass on it.  I pressed pretty hard against the glass to push it into the rubber while wrapping the entire assembly in duct tape.  Set it aside to let the silicone cure overnight.
While I wasn't able to press the glass as deep as it was originally I was able to get it deep enough to be able to fold the metal over the lip of the glass.  I could see the silicone just eking out between the glass and the metal so I am confident I have a nice weather proof seal.
I felt I needed to modify the back of the bucket a bit.  In order to allow for the wires to enter the bucket and allow some cooling I had to open up the hole a some.  I quick test fit showed that I should be able to adhere the LED box inside the bucket against one of the flat sides.
OEM and modified.
I also received my PAMCO electronic ignition so I installed that.  My local electronics shop is closed on the weekends so I will have to wait until Monday to get the correct connectors I need to make everything plug and play.  I have the electronic box hidden in the frame tube which should hide the box and wires nicely.  I am going to secure it with some industrial double sided foam tape.  Right now I am leaving it loose until I get the electrical connections done.
I was also able to get the bearings installed and the triples mounted.  I am glad I went back and re-did the stack height measurements because I needed the thinner shim.  And because I wanted to see how it looked I slid the forks into the trees.  My tires are on order and as soon as the guy that trues my wheels gets back from vacation I will get this baby into a roller.
Offline MoMo
  • Ride like you're invisible
« Reply #208 on: October 26, 2014, 04:27:32 PM »
Nice!  the LED is a good idea as the stock units were equivalent to maybe 3 candles or so...Larry
Offline Harsh
« Reply #209 on: October 26, 2014, 04:29:01 PM »
Yep and it draws less power...win win
Offline Harsh
« Reply #210 on: November 02, 2014, 07:51:43 AM »
Worked on some wiring yesterday since my connector kit and crimp tool finally arrived.  Nothing too exciting, but it is progress.  I managed to make a quick connect for the electronic ignition and it tucks very neatly into the frame rail.  I also did a little rewiring to the front of the harness as well and added a couple extra ground wires.  I also got the bike off the ground.  It now sits neatly on the stands.  If you look closely I gave the carb bodies a little love.  I didn't like the dirty grey look they had so I cleaned them up some to make them shine a little bit.  Sprocket and chains are on order.  I went with stock gearing but did a 520 conversion.
« Last Edit: November 02, 2014, 07:53:52 AM by Harsh »
Offline Harsh
« Reply #211 on: November 07, 2014, 07:12:43 AM »
Starting to get very frustrated that I still don't have my wheels back from being trued.  Tires are sitting in the garage waiting to be mounted and balanced so I can get it into a roller.
Offline Restoration Fan
  • My wife will never call me
« Reply #212 on: November 07, 2014, 09:30:07 AM »
You do nice work.  I like the shinier look of the carbs.
Offline grcamna2
« Reply #213 on: November 07, 2014, 11:23:00 AM »
I'll come down there and true them for you Harsh;if you want to pick them up from the man on Wed. Let me know
Offline Harsh
« Reply #214 on: November 08, 2014, 04:26:32 AM »
Thanks for the offer Bill.  I am supposed to get them tomorrow.
Connected the wiring that would be in the headlight bucket yesterday.  Everything works as advertised and the engine turned over when I thumbed the starter.  I had a weird issue with the turn signal indicator LED in the gauge.  It would only illuminate when the left turn signals were on.  All of the turn signals worked like they were supposed to.  I swapped it out for a spare LED and it works correctly.  Weird since the power for it comes form the same place regardless of the turn signal switch.  The LED headlight is crazy bright.  I will be purchasing one of those for my 750.
Offline grcamna2
« Reply #215 on: November 11, 2014, 01:42:59 PM »
Are those LED headlights pricey ?
Offline Harsh
« Reply #216 on: November 11, 2014, 02:15:14 PM »
No.  I paid $25 shipped for mine.  Although it took the slow boat from the Netherlands to get to me.  There are a few different versions out there that might be a tiny bit cheaper.
here is the one I ordered:  http://www.dx.com/p/20w-2000lm-8000k-motocycle-led-headlamp-w-angel-eye-12v-216822?Utm_rid=67723936&utm_source=shopping&utm_medium=pcs&utm_campaign=paidshopping&?Utm_rid=67723936&utm_source=shopping&utm_medium=pcs&utm_campaign=paidshopping#.VGKHCMmK1LQ
Offline skyline223
    • willtuckermusic.com
« Reply #217 on: November 11, 2014, 06:04:14 PM »
Just read up on the whole build... you do some outstanding work with great attention to detail. Looking forward to future updates!!!
Will Tucker
willtuckermusic.com
Offline tfrasca
    • CB550 Project
« Reply #218 on: November 11, 2014, 06:54:42 PM »
This is definitely the raddest 350 project I've seen. Well done.
TF
Offline grcamna2
« Reply #219 on: November 11, 2014, 07:37:28 PM »
Did you get your wheels yet Harsh ?  ???
Offline Harsh
« Reply #220 on: November 17, 2014, 03:19:00 PM »
Well nothing ever seems to go smoothly.  I finally got my wheels yesterday so I mounted them.  I took the wheels up to Cycle Gear to get balanced since they do it for free.  The front took a bit more weight than I would liked to have seen, but it balanced.  The rear has a noticeable high spot.  You can see it when it rotates in the machine.  They got it balanced, but I don't like it.  I met a local builder yesterday that has a nice truing stand so I may give him a call and see what he says.
Regardless,  I decided to mount the wheels and get the bike into a roller.  The front goes on without issue.  The rear however is another story.  The sprocket I ordered does not fit correctly.  The machined space is too great which allows the pin/bolt to free spin so it will never get tight.  I have already emailed the place I bought it and am awaiting a reply.  I am going to hold off on publishing the name of the place I bought them from to see how they handle the situation.  None the less she is a roller now which will certainly aid me in moving around in the garage.
Stock on left replacement on right.
Stock
Replacement
Offline grcamna2
« Reply #221 on: November 17, 2014, 05:21:45 PM »
What rims are you running Harsh? I should have come down there to do'em right in front of you w/ my own truing stand
Offline Harsh
« Reply #222 on: November 17, 2014, 05:23:27 PM »
I am running the stock wheels.
Offline grcamna2
« Reply #223 on: November 17, 2014, 05:51:05 PM »
I'm wondering if you might have a bent rear rim w/ that high spot? Have you considered using a pr. of alloy aftermarket rims ?
Offline Harsh
« Reply #224 on: November 17, 2014, 05:54:30 PM »
I was hoping to use the stockers to cut down on costs.  I would think a bent wheel would be an obvious find during the truing process.
