Author Topic: 550 petcocks  (Read 672 times)
550 petcocks
« on: September 19, 2006, 11:18:01 AM »
I'll be using a 78 gastank on a project that uses a non-rebuildable single spigot petcock (the face plate is rivoted in place) with a tank exit pipe of approximately 16mm OD. I can get a new petcock, but they seem cheap, disposable. I prefer the older type with the 2 screw face plate, so the packing can be replaced if need be, problem is these are 20mm at least on the supersport. Anyone know if there is a different model that will fit the 16mm pipe?  The 400F petcock is larger diameter also.
Thanks
Offline dusterdude
Re: 550 petcocks
« Reply #1 on: September 20, 2006, 01:16:36 PM »
try pingle
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Re: 550 petcocks
« Reply #2 on: September 20, 2006, 04:48:24 PM »
Thanks man, will do.
