Author Topic: brake fluid leaking from hard pipe nut  (Read 584 times)
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« on: May 30, 2014, 06:56:10 AM »
I have finally figured out what might be my problem with mileage... the hard pipe to the caliper was bent funny to the rubber holder on the fender, and I think it was acting like a spring and holding the pad to the rotor. Derp.
Now that I have the holder bent out of the way so the top of the pipe sits freely, whenever I hold the brake lever, I see fluid seeping out around the pipe at the connection to the caliper. Not coming through the threads, but in the middle of the nut around the pipe. The nut is nice and tight.
I figure it is probably a crack in the pipe flare that is allowing the fluid to seep out. I'm not riding the bike until I get it diagnosed.
Anyone else have a similar issue/solution?
--Evan
1975 CB750K "Rhonda"
Re: brake fluid leaking from hard pipe nut
« Reply #1 on: May 30, 2014, 07:11:21 AM »
If it wont torque down properly and seal, get a new one.  They are cheap and available.
If you have long brake lines, run it directly to the caliper with a splicer(two male ends)
Offline calj737
  • I refuse...
« Reply #2 on: May 30, 2014, 07:26:10 AM »
Whatever is the cause, fix it! Very dangerous despite the mileage impact. And while you're at it, evaluate your pads since this constant rubbing may have worn them prematurely.
Offline evanphi
  • Apparently I'm an
« Reply #3 on: May 30, 2014, 07:50:59 AM »
They are new pads as of last year. No significant wear on them.
I am going to order a new pipe from slingshot cycles. Previous good experience in the past!
--Evan
