Author Topic: Temp variations on exhaust cb550f  (Read 361 times)
Offline Thamuz
« on: June 01, 2014, 07:47:40 PM »
I was trying to figure out why my bike was sounding a little off.  Out of curiosity I used a IR temp gauge.  No matter when or how I tried this, 1 and 4 were 15-20 degrees cooler than 2 and 3.
1977 cb550f stock jets, modified k and m pods, and this muffler I have no clue, baffle is missing.
It dies run rather well otherwise, just is this timing? could that coil pack just not be sparking enough?
Things I have done: all plugs gaped according to manual,  I did do the timing on it recently, changed oil.
At a loss to explain this one. lol
1979 Yami Chopper XS1100s
1978 CB750k
1977 CB550F
1974 CB550k
Parts bike for the 550's
Re: Temp variations on exhaust cb550f
« Reply #1 on: June 01, 2014, 07:55:34 PM »
These bikes run better with backpressure from a baffle, and the pods are not helping.
When was the last time you gave it a full 3000 mile tune up?
Cyl 1&4 running slightly cooler is normal since they have more cooling fins.
Offline Thamuz
« Reply #2 on: June 01, 2014, 08:43:36 PM »
I didn't do forks, and that was last month.   I checked the points and they looked good.  But, if its normal, I won't get too worked up.  lol
The forks are being dne this winter.  so far they are not loose and ride well.  No leaking, yet.
I modded the pods by finding some pvc that fit inside them and was the same thickness ans the carb bodies.  They all stick out into the pod a bit to help with airflow.  I just got stock airbox pieces in a deal and trying to go back to that.
1978 CB750k
1977 CB550F
1974 CB550k
