Author Topic: Just some pictures of my Hondamatic  (Read 4451 times)
Offline ebrown0104
« on: June 02, 2014, 08:34:30 AM »
Started out as this:
After a month-plus of work, here it is:
These are the stock carbs with 42 pilot/130 main/shimmed needles.  Pulled the velocity stacks out of the airbox.  Used foam pads for headphones as filters.  I'm building a set of 77-78 K carbs to use the same way:
Mac 4-1 for K models fits fine... if you have a big enough hammer:
Offline 7T1Burb
Re: Just some pictures of my Hondamatic
« Reply #1 on: June 03, 2014, 09:27:45 AM »
Nicely done!
Tell us a little more about that seat.  I'm on another '77 rebuild and that seat really looks great.
Offline ebrown0104
« Reply #2 on: June 07, 2014, 08:43:21 PM »
I made the seat pan out of fiberglass, and a friend of mine did the foam and cover.  I was going to try and use the original pan but decided that it was huge, heavy, and didn't really contour to the shape of the bike very well.
Just masked everything off (I wanted to use the original hinge and key lock so I have those installed under the tape):
Used an old blanket as a spacer to give me room for backing material, then covered in plastic:
Put down two layers of the woven mat to get a smooth bottom:
Covered with about 4 layers of chopped mat for strength, plus some filler to get the shape I wanted.  Glassed a couple of bolts into the base to install the hinge and lock:
No pictures of the foam, but it's a high-density gray foam.  It's about an inch think where the front seat is, which is just a little too thin.  I'm probably gonna have him put a gel pad in place of the foam since I'm bottoming out on the seat pan over bigger bumps and it's giving me some lower back pain.
Offline 7T1Burb
« Reply #3 on: June 08, 2014, 05:32:47 AM »
Thanks for the great "tutorial" on your seat build!  This will really help as I begin the process of building a seat for the next 750A project that's "in the works".
I have also used the 5lb "adjusting tool" on my MAC system and it worked well.
Nice "DUC"!
« Reply #4 on: June 08, 2014, 07:17:33 AM »
Nice job.  Is the clear coat pealing on the tank?
Offline nixon
« Reply #5 on: June 11, 2014, 06:55:39 AM »
looks good dude.. lower bars definitely suit them IMHO
and the smaller taillight..are you considering bopped /chopped fenders?
cb750a 77, cbr900rr 93 with auto clutch
Riding tip " turn in late, feeling great.  Turn in early,  feeling squirrely "
Offline sanddigger
« Reply #6 on: June 11, 2014, 10:44:02 AM »
ONLY ... ONE  WORD....>  GREAT  LOOKING OH  THAT TWO WORD  :) :) :) ;D ;D 8) 8) 8)
Offline BIKE
« Reply #7 on: June 15, 2014, 05:15:57 AM »
Oh, nice job.
1975 CB750 K5
1977 CB750A
Offline ebrown0104
« Reply #8 on: June 18, 2014, 03:40:18 PM »
It is peeling a little bit.  I'm deciding whether I want to get it re-cleared or just leave it go.  It looks kinda funky, but it matches the rest of the bike.  So, I dunno.
I got the new 1977 K carbs installed and it screams now.  OK, not really, but it did wake it up some.  I have 45 pilots and 135 mains in there, but I run out of power after 65mph, so I'm gonna go up to 140 mains.  Up to 3/4 throttle though it runs great.  I have the timing advanced some, it seems to help throttle response from a stop.
I put on new sprockets and chain.  I went with a 530 x-ring and 17/45 sprockets (stock is 17/48).  It stretches out the gearing a little without killing low end power.  I made a 170-mile run on Sunday at 55-60mph and got about 40mpg.  When I eventually go with a cam and big bore I may drop to a 42 rear sprocket.
Offline colvinry
« Reply #9 on: June 18, 2014, 08:37:45 PM »
Love the seat! Really gives that bike a great, unique look.
Offline POPS 911
« Reply #10 on: July 23, 2014, 02:13:28 AM »
Did you sell the luggage rack and back rest ??
Offline xntrik
« Reply #11 on: October 10, 2014, 08:58:51 AM »
Do you have the stock exhaust?
Offline Grnrngr
« Reply #12 on: December 29, 2014, 11:18:37 AM »
Love the seat and thanks for the "build thread", looks awesome!
'72 CB750-K2 "PopCycle"
'73 CB750-K2 "Barney"
'77 CB750A
'83 Virago 500 (red)
'83 Virago 500 (black)
Offline BIKE
« Reply #13 on: February 15, 2015, 05:49:02 AM »
Gorgeous
1975 CB750 K5
1977 CB750A
Offline jonnycakes
« Reply #14 on: February 15, 2015, 01:43:25 PM »
sweet
'Matic-Fanatic
Offline mdl91881
« Reply #15 on: August 11, 2015, 08:12:33 PM »
Great looking bike!  What bars are those?  Did you lower the bike or stock suspension?
Offline nativerhythm
« Reply #16 on: October 23, 2015, 07:32:28 AM »
Please indicate what sized rear tire you are running.  Your 750A looks great!
