Author Topic: Vetter Fairing mount needed for CB550  (Read 1906 times)
Offline DrMark
« on: September 19, 2006, 04:07:04 PM »
Other than EBAY, Where can I find a fairing mount for a 1978 CB550K? I was given a Vetter Fairing today. Will also need the wiring harness (from the bike, plugs into 9-pin socket on fairing). Any ideas? Thanks, DrMark
1978 CB550K
1983 CB650SC Nighthawk
eldar
Re: Vetter Fairing mount needed for CB550
« Reply #1 on: September 20, 2006, 06:30:41 AM »
I may have a mount. I know if fits my fairing but is too small for my frame. I got it off ebay and was told it would fit a 750, yeah right. Anyways, I dont know what it does fit.
If you can get your measurements, I might have what you are looking for.
Offline DrMark
« Reply #2 on: September 20, 2006, 06:49:11 AM »
Thanks Eldar; What measurements should I make sure to give you? Not sure what the mount looks like as I have always used handlebar mounted units. This will be my first frame mounted fairing. I'll do the best I can....tell me what needs to be measured? Thanks, DrMark
1978 CB550K
eldar
« Reply #3 on: September 20, 2006, 08:10:44 AM »
Well there are 2 mount points on each side of the mount itself. It mounts on the cradle tubes. One set is a little below the neck and the other is about 1/3 or so the way down the tubes. So measure about 4 inches below the neck and about another 6 inches below that on the tubes and go from about the middle of the tubes, not the outside to outside.
I will try to get a pic if I can find my camera. The mount is in decent shape if I remember correctly. I never used it but did buy it used.
Offline DrMark
« Reply #4 on: September 20, 2006, 08:44:20 AM »
I'll do that during my lunch break today...your instructions on where and what were great...thanks!
1978 CB550K
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #5 on: September 20, 2006, 09:23:59 AM »
i'll have to check which ones are vetter, but i have about 8 fairings at my shop. i think they came on every single bike i've ever bought.  ::)
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
georgemii
« Reply #6 on: September 20, 2006, 06:10:21 PM »
I have mount and harness if you still need 'em.
eldar
« Reply #7 on: September 21, 2006, 06:10:16 AM »
I got the measurements but I left them at home when I went to work.  I can get them tonight, unless you decide to go with someone elses mount. Then I will ebay the thing.
Offline DrMark
« Reply #8 on: September 21, 2006, 03:34:03 PM »
I'll list my measurements in the AM....thanks for helping so. If it doesn't fit...I'll F/U with George.
1978 CB550K
