Author Topic: Carbs Cleaned - Engine Won't Start!  (Read 4259 times)
Offline CR125Honda
Re: Carbs Cleaned - Engine Won't Start!
« Reply #25 on: June 10, 2014, 09:23:08 PM »
Actually, no I didn't.  I do think it would be a good idea, however.
Chances are you sealed the pickup tubes with the sealant.
My post was two fold.
First was asking if you removed the petcock prior to sealing, which you did. Good.
Next was asking if you disassembled/cleaned the petcock.
If you have good flow through it and it's not leaking, it should be fine.
As you don't have a "prime" position. you should be able to test the flow by disconnecting the fuel hose(s), putting vacuum on (or sucking on) the vacuum line to the petcock, and watching for a flow of gas.
1974 CB750K4
1974 Kawasaki H2
1970 Triumph 650
1961 Pan/Shovel
Honda Benly 125 Touring
2003 BMW K1200LT
2005 Yamaha R1 Raven
1975 CR125
Ct70's, QA50's
