Author Topic: cb500 oil pump leaking, maybe. Now with cylinder gouging.  (Read 5292 times)
Offline DavePhipps
  • Reading the entire Hi-Perf forum
    • Hillside Technology
« on: June 08, 2014, 10:53:20 AM »
When my son took the left crankcase cover off a lot of oil came dribbling out. It seems to be confined to the oil pump area but I can't pinpoint the exact location. As a precaution I'm ordering the Orings for the pump.
Can anything else in this area leak.
Also I broke the bit on my impact driver trying to remove the screws from the oil pump. I'm going to drill through the screw heads but can't remember what size bit I've used in the past. Someone raided my tools and made off with many of them including the mystery size bit I used to use. So suggestion on bit sizes?
« Last Edit: June 21, 2014, 07:14:17 PM by DavePhipps »
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline goldarrow
  • one day, i'll be an
Re: cb500 oil pump leaking, maybe.
« Reply #1 on: June 08, 2014, 12:32:47 PM »
Oil pump seals or shift shaft seal.
CB550 K0
Offline DavePhipps
« Reply #2 on: June 08, 2014, 12:45:46 PM »
Shift shaft seal is fine so that leaves the oil pump Orings?
hmmm... saying Orings make me want onion rings, YUMMY!
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline goldarrow
« Reply #3 on: June 08, 2014, 05:09:14 PM »
4 orings for oil pumps. 1 for pump to case, 1 for pump cover, and 2 for dowels.
CB550 K0
Offline billingstitan
« Reply #4 on: June 08, 2014, 09:19:19 PM »
You'll want this one for the oring under the oil pump cover: The o-ring for the oil pump cover is sized 46x2mm. Honda's part no is 91305426003 - it's for a goldwing - but it's the only one available.
My advice - don't use aftermarket on this part - I did, and it ended up .1" too thick and starved my bottom end resulting in a spun bearing - that part referenced above works perfectly and is available at most dealers and definitely online.
Calling upon my years of experience, I froze at the controls.  ~Stirling Moss
2014 Ducati Monster 796
1977 CB550K http://forums.sohc4.net/index.php?topic=138289.0
1977 CB550K
1972 CL175
2000 Kaw Nomad 1500
1992 KDX 200
2001 Honda 80R
Past Bikes:
1973 Kaw 900Z1
1970 Yamaha 350RD
2003 Yamaha VStar 1100
2001 Suzuki GS850
Offline goldarrow
« Reply #5 on: June 08, 2014, 09:45:43 PM »
Honda oring is great.  Aftermarket orings work just fine.  Don't blame on those orings if you starved your top end.
CB550 K0
Offline Bodi
« Reply #6 on: June 09, 2014, 12:06:31 PM »
.1" too big? That's 2.54mm! I don't see any way you can blame an O-ring for that. If that part number is, in fact, a 46x2 O-ring - although metric sizes can be difficult to find especially in singles, any one the same size must be the right fit. The material... who knows, but it will fit properly.
« Last Edit: June 09, 2014, 12:09:23 PM by Bodi »
Offline DavePhipps
« Reply #7 on: June 09, 2014, 03:04:58 PM »
How did I mss all these replies?
I know the Oring under the cover of the pump isn't leaking, however there seems to be a boatload everywhere else in the area behind the pump. Once the bike actually starts I'm going to run it with the case cover off and see where it's all coming from. Don't worry I'll clean the area spotlessly first.
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
« Reply #8 on: June 10, 2014, 10:18:04 PM »
@bodi & goldenarrow - with all due respect - I'm not "blaming" anything - it was my mistake that's for *(#@ing sure  :-\ I thought I found the answer, failed to do more research on the forum for differing opinions, and suffered the consequences.
That said - there is absolutely no question the slightly thicker aftermarket o-ring starved the bottom-end on my 1977 CB550 by dropping oil pressure, which resulted in a spun bearing.
I got pointed in this direction by ill-informed advice from a well-meaning forum post, so it's important to point out the catastrophic result of an "almost right" sized o-ring under the 550K oil pump cover to other members to ensure they have accurate information.
Whether folks heed my hard-earned, expensive lesson-learned or not is their own choice. I do feel obligated to the community to share it, however.
Bottom-line: if the o-ring under the oil pump cover is even slightly too thick, it impacts the operation of the oil pump by pushing the cover further away from the pump's rotor and dropping the oil pressure.
Perhaps this is unique to 1977-78 CB550K's - I don't know, these are the bikes I run so these are the bikes I have experience with.
I DO know beyond question that what caused the issue with mine was a slightly thicker aftermarket o-ring.
As far as "blaming" ... I've *#%(ed up more stuff on my bikes than I can remember over three decades of riding, so I'm sure not concerned about blame. I don't know anyone who has spent any time working on bikes that doesn't have similar stories.
I am concerned that folks get straight info. I don't submit or comment on posts unless I'm certain about what I'm talking about - mostly, I ask questions - but I do know my way around a bike.
 Again - submitted with all due respect.
1977 CB550K
1972 CL175
2000 Kaw Nomad 1500
1992 KDX 200
2001 Honda 80R
Past Bikes:
1973 Kaw 900Z1
1970 Yamaha 350RD
2001 Suzuki GS850
« Reply #9 on: June 11, 2014, 08:35:12 AM »
I posted the size a very long time ago and have used both aftermarket and genuine Honda after my generic supplier would only sell in 100 lots. I can only guess that the 46 x 2 you were supplied was a unified "Equivalent" and slightly thicker which i am afraid to say some suppliers do way to regularly as they mostly sell for hydraulic purposes and consider it not to matter
« Reply #10 on: June 11, 2014, 10:20:06 AM »
That sounds plausible, bryanj -- I wouldn't doubt the commercial ones were simply not as exact or consistent in the sizing specification as Honda's, as it did seem folks on here had run those aftermarket o-rings with no issues ... and prob still do.
I bought a 100 lot o-rings from a commercial supplier/part number recommended from the forum, and after the whole debacle happened (i.e. my engine blew) -- I ran across a post with that alternative OEM o-ring (Honda part 9130542600) and got one for the oil pump in the replacement engine, along with a few spares.
There was a noticeable difference in size considering they were almost the exact same specifications 'on paper.'
And, full disclosure, I was a dumb*** because I noticed my oil light flickering here and there after changing the oring, but my bike had been down for about six weeks while I did a slew of other maintenance: bearings, forks, tires, brakes, bars, etc., etc., etc. -- and I just didn't immediately connect the dots.  :P
I thought I had a bad sensor or poor connection as there was not a noticeable change in the engine sound. I didn't ride the bike a lot - but all it took was one 15 mile 'test run' to hammer the bearings into oil pan glitter.
In any case - I swapped the o-rings on the oil pump before I took the damaged engine out (it still runs), and lo and behold the oil light flicker immediately resolved itself. So I've no question that was the issue.
Fortunately, I did find a great replacement engine at a great price and was back on the road in a couple weeks ... but it still ended up costing me $700 w/ the shipping, so that was an expensive o-ring, lol  :o
But, hey, at least I found an engine!  ;D
1977 CB550K
1972 CL175
2000 Kaw Nomad 1500
1992 KDX 200
2001 Honda 80R
Past Bikes:
1973 Kaw 900Z1
1970 Yamaha 350RD
2001 Suzuki GS850
Offline Lostboy Steve
« Reply #11 on: June 11, 2014, 10:27:02 AM »
Snap-on makes a very large bit. Phillips 3. Part Number: fps32e. Its the bit I use for just about everything. As far as the oil-pump goes. I had the same problem on my 550k. If the oil pumps are the same (not sure) its most likely the pump cover o-ring. I did all the seals and o-rings while I was in there.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline DavePhipps
« Reply #12 on: June 13, 2014, 02:09:57 PM »
Ordering the OEM orings this weekend, thanks for the part #. That makes it much easier.
Will be getting the #3 bit also.
Now back to sorting wiring on this bike.
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline goldarrow
« Reply #13 on: June 13, 2014, 03:24:51 PM »
Might want to have drill bits and left hand thread easy out handy, just in case.....they come in handy when needed....just saying...
CB550 K0
Offline DavePhipps
« Reply #14 on: June 17, 2014, 05:08:23 PM »
Looks like easy out is the option, or drill to the countersunk area and carefully remove the screwhead. I've now broken my impact driver bit ad chewed up the screw heads... oh joy.
Does anyone know what length these are, and it there a stainless allen bolt that can be substituted? I'm really sick of screws on bikes.
I almost forgot to mention this fun little bit. The oil light comes on a very low RPMs. This is a new behavior. The bike sat for almost a year due to perdonal illness, injury, and lack of funds. When parked it leaked but the oil light never cam on at low RPMs.
« Last Edit: June 17, 2014, 05:24:30 PM by DavePhipps »
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
« Reply #15 on: June 17, 2014, 06:45:06 PM »
Oh s**t, brother ... proceed carefully, that's exactly what mine did before it spun a bearing. I have a couple oil pumps for 77 CB550s I picked up when troubleshooting the issue so if you're needing one let me know. Not sure about the cross-compatibility with years.
1977 CB550K
1972 CL175
2000 Kaw Nomad 1500
1992 KDX 200
2001 Honda 80R
Past Bikes:
1973 Kaw 900Z1
1970 Yamaha 350RD
2001 Suzuki GS850
Offline DavePhipps
« Reply #16 on: June 17, 2014, 07:07:07 PM »
I'm not riding it right now anyway. Not until I get all the leaks and other assorted bits fixed. I have my trusty FZR to get me around.
I'm going to have the engine apart down to the crankcases ans oil pump off. Anything specific I should look for other than oil pump rotor clearance and plugged oil jets/passages?
Thanks for the pump offer. I'll keep that in mind if mine turns out to be bad.
« Last Edit: June 17, 2014, 07:11:57 PM by DavePhipps »
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline goldarrow
« Reply #17 on: June 17, 2014, 07:51:26 PM »
Take your time with the drill bit and left hand thread. It will come out without damage the thread.
CB550 K0
Offline DavePhipps
« Reply #18 on: June 17, 2014, 08:46:07 PM »
DOes anyone know what size drill bit and extractor I'll need for this? These screws aren't listed in the Fiche anywhere.
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
« Reply #19 on: June 17, 2014, 08:46:34 PM »
Glad you've got another ride - that makes the down time much more bearable.
I'm no expert on those oil pumps (he says, bolting in a replacement engine  :P) -- but they seem relatively bullet-proof. The manual lists the specs.
You can see if you're getting oil up top by just pulling a valve adjustment cover on each side of the engine and turning it over with the engine run switch turned to 'off'.
You should see be able to see the oil pumping into the area. On the 77 CB550 the oil wells up from around the end of each side of the camshaft. Note - I'm not saying to pull the whole valve cover, just the round tappet hole covers. You can peek in there and see it flowing.
I'm sure you already double checked the oil level to ensure it didn't leak to a critically low level.
The only other suggestion I'd have is to pull the oil pan and check the oil screen and the tube to ensure those are clean and free of obstructions.
Sorry about the stripped nuts - we've all been there  >:(  Those left hand drills have worked for me every time - just go easy. And watch those oil pan bolts, those SOBs strip easily as well (ask me how I know)
1977 CB550K
1972 CL175
2000 Kaw Nomad 1500
1992 KDX 200
2001 Honda 80R
Past Bikes:
1973 Kaw 900Z1
1970 Yamaha 350RD
2001 Suzuki GS850
« Reply #20 on: June 17, 2014, 08:51:50 PM »
Based on info I got from the forum, it looks like those screws are M6 x 20, 20mm full length, approx 16mm of actual thread. Sounds like you can replace with a stainless allen head bolt - here's where I got the info: http://archives.sohc4.net/index.php?topic=8614.0
1977 CB550K
1972 CL175
2000 Kaw Nomad 1500
1992 KDX 200
2001 Honda 80R
Past Bikes:
1973 Kaw 900Z1
1970 Yamaha 350RD
2001 Suzuki GS850
Offline brooze72
« Reply #21 on: June 17, 2014, 08:59:21 PM »
Don't forget the oil sender switch, mine also started coming on at low rpm, removing & cleaning did squat, new switch was the answer.
1972 CB500K1 - restored rider
1981 CB650C - new project
Offline DavePhipps
« Reply #22 on: June 17, 2014, 09:15:13 PM »
Thanks billingstan, and brooze do you mean the oil pressure switch? Heck I'm not sure if that's the right name for it, but it screws into the top of the oil pump.
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
« Reply #23 on: June 17, 2014, 09:33:46 PM »
Yup - that's the one -
1977 CB550K
1972 CL175
2000 Kaw Nomad 1500
1992 KDX 200
2001 Honda 80R
Past Bikes:
1973 Kaw 900Z1
1970 Yamaha 350RD
2001 Suzuki GS850
Offline Bodi
« Reply #24 on: June 18, 2014, 09:24:23 AM »
Not blaming anyone... more of a poorly worded poke at your dimensioning: I think you must have meant 0.01" oversize, at the most.
A 0.1" larger cord would be over twice as thick as the original.
