Author Topic: 78 K8 seat lock issue  (Read 342 times)
Offline Thamuz
« on: June 09, 2014, 01:28:02 PM »
I got this bike with no keys, what a surprise.  The seat is locked onto the frame but not the seat pins.  I can turn it.  Im not caring if the lock is destroyed as its going to get replaced with a matched seat and ignition.
I have tried a flatblade, just didn't work.
1979 Yami Chopper XS1100s
1978 CB750k
1977 CB550F
1974 CB550k
Parts bike for the 550's
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: 78 K8 seat lock issue
« Reply #1 on: June 09, 2014, 04:02:01 PM »
Does this mean you removed the seat pins and can turn the seat? If so, then you should be able to turn the seat far enough (about 90 degrees) to disengage the seat latch. This will likely require removing the grab bar (if so equipped).
If you have not removed the hinge pins, then do so and follow the steps above. You might be able to lift the seat enough to unbolt the latch from the bottom of the seat. Once the latch is freed, you can disassemble the seat latch lock cylinder and remove the little brass lock pins. Then the seat latch lock would function like the tank flap lock as a "pseudo" lock.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Thamuz
« Reply #2 on: June 09, 2014, 05:51:55 PM »
the pins are gone.  I am stuck at this thing called "work" I will try it tonight.  forgot about that.  Im not used to getting bikes with seats. :D
1978 CB750k
1977 CB550F
1974 CB550k
