Author Topic: CB500/500 sealing pucks, rubber nickels, whatever.  (Read 442 times)
Offline DavePhipps
  • Reading the entire Hi-Perf forum
    • Hillside Technology
« on: June 09, 2014, 08:13:27 PM »
Annoying little things that don't come in most aftermarket gasket kits. They fit in the top of the head and seal those six holes
My question is what exactly are they sealing? What happens if they leak?
It seems strange to seal these holes when right next to them if the cam chain opening which goes all the way through the engine.
Please enlighten this curios mind.
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Re: CB500/500 sealing pucks, rubber nickels, whatever.
« Reply #1 on: June 09, 2014, 08:52:21 PM »
You've got 6 bolts (not studs) helping seal the head to the cylinder.
On the 750, these bolts are between the cylinders, and to not interfere with the cam towers and valve train, they are recessed into the deck of the head.  Once in place, the hole the bolts are recessed into needs to be sealed.  The puck fits in the recess, and is pressured in place by the cam tower.
This is a 750 head, but the holes where the pucks go are access holes to these 6 bolts.  Thru the fins in the front and back you can see these bolts.  The pucks seal out the outside world and keep oil where it should be....
Please nevermind the red arrows.
