Author Topic: 650 cam alignment issue  (Read 3713 times)
Offline goldarrow
  • one day, i'll be an
Re: 650 cam alignment issue
« Reply #25 on: June 12, 2014, 10:49:45 AM »
That looks good.  Spin it around few times and be sure the notch land on the same spot
CB550 K0
Offline rb550four
« Reply #26 on: June 12, 2014, 04:40:22 PM »
 If you reset the cam just the way it was  written ,  the 1.4T, the cam index mark ,and the cam chain sprocket punch marks, that should be all you need.
The cam check is a 3 way check , 1st the 1.4T Check and the cam index mark level with the head on the front, the cam chain sprocket has 2 punch marks when looking at it from the left side, one mark should be at 9 o'clock and the other at 3 o'clock level with the plain of the head.  Being that it is a 4 stroke, on the 4th revolution  of the indicator at the 1.4T, in a clock wise motion, your engine should be back to where you set it, all of these 3 indicators should show up where they are supposed to be, thus the stars are aligned and all is right with the world.
« Reply #27 on: June 12, 2014, 11:54:45 PM »
you mean two revolutions?one will leave the notch 180 from where it was,the second will return it,the piston has now done four strokes.
Offline trueblue
« Reply #28 on: June 13, 2014, 02:31:57 AM »
Dave, it seems that we are wasting our breath with this crowd.  We have both said numerous times that it doesn't matter forwards or backwards.  There is always at least one who will chime in and say that they had/a buddy had a cam 180 out.  It seems never ending and quite often it is the same people.
1979 CB650Z
« Reply #29 on: June 13, 2014, 02:40:26 PM »
not wasted so much Andrew,people read and learn but don't always post?
Offline Bodi
« Reply #30 on: June 13, 2014, 02:57:33 PM »
I don't know... people apparently read the thread and it's stated "front or back makes no difference, to prove it set it one way then turn the crank one full turn and see where it faces"... then they post the same nonsense "notch must face forward". Pity if someone wasted time turning the cam 180 because of this moronic advice. 180 degree cam position counts in some - maybe most - engines but NOT IN THESE!
Offline rb550four
« Reply #31 on: June 13, 2014, 03:00:41 PM »
Dave,
2 or 4 , it's still going to be in the same place.  Many , many, okay many years ago in high school shop class, my old industrial arts teacher said  here's an easy way to remember how to get back to where you started 2 turns for a 2 stroke, 4 turns for a 4 stroke. For some reason , sht like that has been popping out of my head lately, and I'm still not sure if it makes a bit of difference on a 2 stroke.  It's like when you see something....kind of hard to unsee it I guess.
Trueblue, I took the instructions from the Clymer manual and posted it earlier...it says forward. It may well work in the rear position  but, that is not what the manual states, I do everything by the book. Sorry if I offended you.
« Reply #32 on: June 13, 2014, 03:04:46 PM »
your industrial arts teacher was misinformed and passed on his mis information?its one for a two stroke and two for a four stroke.
Offline Vinhead1957
« Reply #33 on: June 13, 2014, 03:46:50 PM »
I knew this would get attention!   Easy Dave
Offline Tews19
  • I am no
« Reply #34 on: June 13, 2014, 06:11:28 PM »
Lol. So in reality When it was fine facing back? Lol. Well I have the confidence now to tackle on another!
1970 Honda CB750 survivor.
Offline rb550four
« Reply #35 on: June 13, 2014, 08:37:22 PM »
Oh, sure ,of course that  teacher would give us bad information, I never liked that old  bastard anyways. Good thing I don't work on 2 strokes. I guess that's why he was a teacher and not a fckin mechanic.
« Reply #36 on: June 13, 2014, 08:44:14 PM »
Do I need to do a cam alignment on my RD??
Offline rb550four
« Reply #37 on: June 13, 2014, 08:48:13 PM »
Only if you can't keep pressure in the rear tire.
« Reply #38 on: June 13, 2014, 09:01:29 PM »
And synchronize the points?
Offline goldarrow
« Reply #39 on: June 13, 2014, 09:03:57 PM »
Does it do 70mph 2hrs straight?
CB550 K0
Offline rb550four
« Reply #40 on: June 13, 2014, 09:10:09 PM »
Sync the points? Naaaa, that'd be for the front tire.
« Reply #41 on: June 13, 2014, 09:37:43 PM »
No, does 80mph in the twisties!
Offline trueblue
« Reply #42 on: June 14, 2014, 01:29:49 AM »
Actually in ANY 4 stroke piston engine engine you can't have the cam 180 out, it is not possible to do.  You can on the other hand have the distributor or injector pump 180 out.  That it 100% possible and has been done many times, then people blame the cam.  The cam turns 180 degrees for every full turn of the crank.  If you think the cam is 180 out turn the crank one full turn and it is correct.
Not offended, was just tired last night and getting a little short on patience.  I realise that clymers say to face the notch forwards, but what irks me is when people who have no clue on how an engine functions start telling people who are trying to learn that they need to pull the cam to fix up a 180 out scenario.  When all they need to do is turn the crank through one full turn.  If people would just pick up a book on basic engine function and have a good read before they pick up a spanner, then there would be a lot less people giving bad advice to people who don't know any better. ;D
1979 CB650Z
« Reply #43 on: June 14, 2014, 02:01:37 AM »
you can be 1 degree or 179 degrees out on the cam but not 180!on say car engines with meshed gear drive where you line up the dot to dot,try leaving the crank dot up and the cam dot up?then rotate 360 itll be dot to dot again,dont try this on a holden v8 where you space nine chain links inclusive on the dots!
anyone who didn't know would just line those two dots up?
« Last Edit: June 14, 2014, 02:08:35 AM by dave500 »
Offline Bodi
« Reply #44 on: June 15, 2014, 07:16:27 AM »
It matters on some engines: on a twin cam engine it is important to have both cams the same....
« Reply #45 on: June 15, 2014, 12:33:40 PM »
pair the cams,then turn it 360,where are the timing marks?
Offline trueblue
« Reply #46 on: June 16, 2014, 02:53:46 AM »
We aren't comparing cams to cams, we are comparing cams to cranks.  ;)
1979 CB650Z
« Reply #47 on: June 16, 2014, 12:31:49 PM »
twin cams must be in phase.
